32inch BFGs?
Old 11-06-2007, 09:05 AM
penangtoy's Avatar
Originally Posted by ninjarunner
U pick which one you would rather drive
actually i would drive the far left set up. could you tell me the setup? as i am only doing mild 4wheeling. anyway thanks for everyones feedback
Old 11-06-2007, 12:59 PM
emptypockets's Avatar
FWIW, here are three pics to help you compare tire sizes and the look they give. The first is stock 265/70's with a 2.5" Daystar spacer lift. Second pic is 265/75's with Daystar 2.5" front and LC coils in the rear. The final pic is 285/75's with 2.5" Daystar spacers front and LC rear coils. Performance and looks wise, the 285's win hands down. IF you stick with an all terrain, upper a arm clearance will be fine with stock 16x7 wheels and rubbing will be very minimal.
Old 11-06-2007, 01:44 PM
ninjarunner's Avatar
I ran the stock wheel with 285/75/16 for a year with barley any rub, I loved them, they were just not big enough, I have 315/75/16 now, and those are just right for what I do. you should get the lift and do the 285's trust me you will be very happy, I have some pics of mine with the 285's and a small rock pile if you like.
Old 11-06-2007, 03:27 PM
penangtoy's Avatar
yes more picts to inspire me as my tires are almost done and even being in socal one has to prepare for rain. can you post picts on this forum? thanks
Old 11-06-2007, 04:27 PM
  #25
tntempest's Avatar
I have 275/70/16 and it made my speedo more accurate. But all tire makers have different true o.d.'s and when you get into inch sizes they can be really innacurate. So tire A in 1 size may not rub when tire B in the same size will.
Old 11-06-2007, 04:42 PM
  #26
crolison's Avatar
I have 265/75/16 bfg ats and they dont rub and are 31.7 inches tall
Old 11-06-2007, 06:55 PM
  #27
Djlarroc's Avatar
Do you guys think the manufacturer's OD measurements are accurate? For example BFG's 255/85/16 says: 33.3, and Interco's says: 32.7. I've read that Interco runs bigger, while BFG is true, so is that 32.7 closer to the 33.3? or do you guys think they are true and the BFG really IS taller?
Old 11-07-2007, 04:24 AM
  #28
Are you looking at the Trxus M/T? Typically, a 255 is taller and narrower than a 285. But, 32.7" does seem small diameter wise for a 255. The only way to know for sure is to measure one in person, or contact the company for more information. It might be a misprint.
My 285 Wild Spirit TXR II's run 32.8" tall and 11.3" wide. The 255 TXR II's run 33.2" tall and 10" wide. After actually measuring my 285's, they run exactly the same size as what they publish on the web. I haven't measured a 255, but have seen one in person and they are taller than my 285.
There might be that much difference in 255's between Interco and BFG, but I would call/email Interco to confirm, just for piece of mind. FWIW, after doing a ton of research on 285's, I learned that the Trxus's do run a little smaller than most other tire companies in the same size tire.
Old 11-07-2007, 07:26 AM
  #29
Djlarroc's Avatar
That's good to hear. I'm thinking of getting the trxus 255, but in a sense want the shortest/widest 255/85 I can find. I'll email interco to dbl check, but everywhere I've seen shows that tire at 32.7x 10.1. Don't mean to hijack, but for other members, this is good info to look at when trying to squeeze the biggest tire you can. Most manufacturers do run different in actual size. Just like the wheels I bought, Pro comp listed them at 30lbs each, and the UPS tracking # states 23lbs each. Emptypockets, good to see you do your research as well.
Old 11-07-2007, 07:50 AM
  #30
Glad my info helped! I spent about 6 months researching tires before I decided on mine. The TXR II's I ended up getting are awesome tires for the buck! For pics, click on my link in my sig and go to my cardomain site.
Old 11-07-2007, 07:57 AM
  #31
Djlarroc's Avatar
Thanks, I didn't even know they sold TXR II's in a 255/85 as well. Where do you think I can find info on them? I've googled "255/85" many times and had thought I had seen all the tires available in that size. So 6 mos huh? That means I only have 5 more mos to go! Just in time for wheeling season lol.
Old 11-07-2007, 09:33 AM
  #32
Well, I actually started looking for new meats well before my old tires were shot.
Here's a link to the Multi-Mile tire site:
http://www.tbcprivatebrands.com/mult...ine.asp?id=284
Do some searching on the site and see what area dealers have them. You shouldn't have any problem finding them in Denver. BTW, mine were $600 out the door, mounted and balanced. Good luck!
Old 11-07-2007, 02:42 PM
  #33
geigerz2001's Avatar
No rubbing. Just did it past weekend at 4wheelparts too.
Although I have to go back and have them rebalance the tires. If I were to do it again I would rather buy from Americas Tire than 4wheelparts for sure.
Old 11-07-2007, 03:58 PM
  #34
penangtoy's Avatar
are the prices better?
Old 11-07-2007, 06:47 PM
  #35
Djlarroc's Avatar
Got some news. CK my name for a recent thread.
Old 11-07-2007, 08:58 PM
  #36
Prices are definitely better at Americas Tire
But i got a good deal from 4wheelparts via the offroading expo. At first I went with 4wheelparts thinking they should be experienced with putting on bigger and heavier tires. But what I found is that they are sort of jack of all trades not experts at anything in particular. They definitely dont have the haweka adapter. Their workmanship is sort of sloppy but that really depends on each specific tech. I've always been happy going to Americas Tire with my BMW but I thought I d try a different place this time. Of course not all the Americas Tire shop have the adapter either but at least some of the shops have heard of it. Oh well.....
Old 11-07-2007, 09:46 PM
  #37
mikes19984x4's Avatar
Originally Posted by onesojourner
just so you know you can not get any 32x11.5 tires for a 16 inch wheel. kind of sucks 11.5 is a great width.
well, last time i checked, a 285/75/16 is "labeled" as being a 33x11.5x16 tire, even though on a tire size calculator it says 11.2 inches. but in reality, it is almost impossible to find a tire that is "exactly" the size that is claimed by the manufacturer.
Old 11-08-2007, 05:14 AM
  #38
onesojourner's Avatar
but 285/75 16 is a 33 that is a bit tougher to make fit. 32x11.5 is a perfect size tire for the wheelin we do.
nvwiggins
13
06-16-2016 03:05 PM
muddpigg
11-02-2015 05:36 AM
87SR5justin
09-29-2015 02:45 PM
94toyy
12
09-14-2015 06:18 AM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: 32inch BFGs?
