31x10.50R15 tires too much on a 2.7L?
Old 06-27-2004, 12:33 AM
Nic
Nic's Avatar
I'm in the process of cleaning up some alloy wheels I have recently purchased. Once I am done, I plan to buy another set of tires. I currently have 235/75R15s. I was thinking about going to 31x10.50R15s so I can a little bit more ground clearance.
My truck is stock. Are there any problems with upgrading to this size, especially since I have the 2.7L?
Plus, I need to make sure that the 31x10.50R15s can fit this type wheel? Anyone know that too?
Old 06-27-2004, 03:46 AM
2001 VA4Runner's Avatar
My 1999 Tacoma ex cab 2.7L, 5 speed came with 31x10.5x15 from the factory. You should not have any problems. The rim you have pictured are the exact rims that are on mine.
Old 06-27-2004, 05:48 AM
superjoe83's Avatar
my '99 reg cab came with 265/75/15's which are approx. 31's, i think that if the Tacoma came with alloys, then 31's were the tire that came on it, i am guessing that yours came with steel wheels?
Old 06-27-2004, 06:10 AM
Highland Runner's Avatar
My old Tacoma had those wheels stock with the 31" tires. You need to check the axle code. I think mine was 4.10. I also had a 93 truck with the 235/75/15 tires and steel wheels. I put the 31's off my 4Runner on the rear one day to see what it was like. No noticible power loss, but they were on only 4 hrs.
Old 06-27-2004, 07:09 AM
Nic
Nic's Avatar
Great, that makes me feel better.
Yeah, my truck currently has the steel wheels on it. I have to remove the clearcoat off one more of the alloys before I can get some tires put on. I wouldn't be taking off the clearcoat, but the wheels I bought turned out to be kinda rough when they arrived-they were probably on a model older than mine. The 3 I've already finished look good though-just so time consuming.
But, in the meantime I can price around for the 31s.
Thanks for the help.
Old 06-27-2004, 08:06 AM
BajaRunner's Avatar
I had those size tires on my 89 4-banger, and it was fine.
Old 06-27-2004, 08:08 AM
Cebby's Avatar
I'll second the "check the gearing". That's what really matters.
Old 06-27-2004, 11:46 AM
Nic
Nic's Avatar
Excuse my ignorance, but where would I look to check?
Old 06-27-2004, 12:48 PM
Cebby's Avatar
Sticker in the door jamb.
Old 06-27-2004, 02:39 PM
Nic
Nic's Avatar
Hmm, OK. I looked yesterday. Must have missed it.
Old 06-27-2004, 04:39 PM
jimbo74's Avatar
i went from 195/70/14s on my 1985 toyota pickup 4x2 all the way to 31s..... a noticeable power loss, but i can still drive it fine.....
1uzRunner
63
11-10-2018 03:58 PM
firstgen88
10-07-2015 04:53 PM
Williamemslie
14
10-05-2015 09:28 AM
128keaton
09-03-2015 05:09 PM
matthew138
09-03-2015 08:21 AM
Quick Reply: 31x10.50R15 tires too much on a 2.7L?
