YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-16-2004, 05:10 PM   #1 (permalink)
AgRunner06's Avatar
Send a message via AIM to AgRunner06
3.slow: Oil pan gasket...(pics)
Anyone here ever done an oil pan gasket or resealed it on the 3.slow?
As you can tell from my pics, it looks like the majority of my oil is leaking from the oil pan. Upon further inspection it appears that it is leaking from almost all around the edge of the pan. However the oil only goes a short way up the block so I'm figuring that it is the oil pan gasket/sealer. I already tried some gasket sealer stuff that you put in the oil but it didn't help much. Right now I'm going through about a quart ever 1K miles. I was looking in my Haynes manual and suprisingly it didn't seem too involved. They didn't mention anything about having to pull the motor or lift it.
So who's done it and how hard was it to do?
Thanks for the input.
__________________
"I'm your huckleberry." - Doc Holiday
- '93 4runner - Sold!
Current Ride - 2001 Chevrolet Silverado 1500 ext.cab, pewter, 5.3L, 3.42s, fully loaded, 68K miles.
FREE ROCKET!!!!
AgRunner06 is offline
Sponsored Links
To remove this ad, register today!
Old 02-16-2004, 06:43 PM   #2 (permalink)
I would say, check your valve cover gaskets first because they leak more frequently than the oil pan. I work at a toyota dealer and we see that more often than pan reseals.
Just my 2 cents.
Mike.
__________________
1997 Toyota 4Runner Limited, 5vz-fe, auto, E-Locker, 265/70/16 BFG Allterrains
1989 Toyota Xtracab Pickup 3vz-e, 5 speed, 50L aux fuel tank, 8000 pound Ramsey winch, Tube bumpers front and rear
http://www.geocities.com/vdubster1
vudbster is offline
Old 02-16-2004, 07:00 PM   #3 (permalink)
Brendan's Avatar
Send a message via MSN to Brendan
while we're on the subject of oil leaks. I had a moderate leak for about 6 months that I finally decided to fix. It seems to have stopped and all I had to do was tighten the oil pan bolts. I had oil spots on the hood though as well. Is it possible for a leaking oil pan to somehow get up to the hood?
EDIT: 22re
__________________
MSN/Email - sizzlechest AT shaw DOT ca
1992 "Truck"
1978 Land Cruiser FJ40
pig and elephant DNA just won't splice :(
***DO NOT CLICK HERE***
Brendan is offline
Old 02-16-2004, 08:10 PM   #4 (permalink)
AgRunner06's Avatar
Quote:
My valve cover gaskets were done a little over a year ago when the 2nd HG recall was done.
I may see about tightening up those bolts. It's worth a shot and it won't take too much of my time.
Thanks for the info.
__________________
FREE ROCKET!!!!
Old 02-17-2004, 07:08 AM   #5 (permalink)
beachtaco's Avatar
Quote:
it's a pain in the ass. i did my oil pan when i had my front diff pulled. i don't see a way to do it any other way. once the front diff is out of the way, you'll have access to most of the bolts. you'll have to remove the front transmission cover plate and bracket to get to the back oil pan bolts. you can see the brackets in your second picture that connect/support the transmission to the engine block. the only other issue i had was clearing the oil pan with the drag link. i think i cranked my wheel right and it cleared fine.
__________________
Once you’re a surfer. You’re done. You’re in. It’s like the mob or something and you’re not getting out. – Kelly Slater
beachtaco is offline
Old 02-17-2004, 07:09 AM   #6 (permalink)
beachtaco's Avatar
i'm assuming you have to pull the plenum off to get to head bolts.
__________________
Old 03-09-2004, 02:28 PM   #7 (permalink)
Send a message via Yahoo to tuquoque
how did this go for you? Pretty hard/easy or somewhere in between?
__________________
1990 4 runner 4wd, 3.slow, bone stock
Beware when casting out your devils, you don't cast out the best thing about you.
tuquoque is offline
Old 03-09-2004, 08:46 PM   #8 (permalink)
AgRunner06's Avatar
I didn't replace the oil pan seal. I did, however, take off the skid plate and tighten up almost all the oil pan bolts. I did find some that struck me as being on the loose side. I'm hoping that helps fix the problem. Otherwise, with the skid plate off, it looked like it might be a feasible task as long as you can get the bolts that are between the back of the motor and the tranny. It's a tight fit. I think there was one bolt that I wasn't able to get a socket on, but I didn't have a swivel either. It looks like you might be able to pull the oil pan out the front when the skid plate is off. But I could be wrong.
I hope that helps.
__________________
FREE ROCKET!!!!
Old 03-12-2004, 10:28 AM   #9 (permalink)
After checking or fixing the valve cover gasket look at your oil cooler.
I had leaks in both places. Your pics look very familiar.
I knew my valve cover gasket was leaking, but after fixing that i still dripped oil from the same spot. After changing the oil cooler gaskets I have been completely dry. Changing these was very messy and frustrating and it is bolted on very tight.
On a unrelated side note, I also replaced my steering seal at the fire wall.
It was a miracle worker for reducing the loud valve ticking noise.
Astralplane is offline
Old 03-12-2004, 10:37 AM   #10 (permalink)
If you do have to drop the pan, it's a lot of work (for 4x4s), but not difficult. You have to pull the front diff, which can be a real bear. I just wrestled mine out without a jack - don't recommend that approach but it worked for me. You do have to jack the engine up 2 or 3 inches to get the pan free. To get to all the bolts on the pan, you have to remove the stiffener brackets (someone mentioned that above). When you put the pan back on you should rehearse a few times before you put the sealer on it so you can see how to work it back in without scraping the sealer off against all the obstacles.
Also, don't over-torque the pan bolts - I think they're 8 ft. lbs.
JohnStra is online now
Old 03-12-2004, 10:47 AM   #11 (permalink)
AgRunner06's Avatar
I also had the seal on the oil cooler leak. It was supposedly fixed when my HG recall was done over a year ago. How can I tell if the oil cooler is leaking? Actually, where is the oil cooler? I know it's down there somewhere, just not sure where.
Thanks
EDIT: Astralplane, check out this thread, http://www.yotatech.com/showthread.php?t=28607.
__________________
FREE ROCKET!!!!
Old 03-12-2004, 10:58 AM   #12 (permalink)
outdoorfever's Avatar
Send a message via AIM to outdoorfever
yea you gotta take off the front diff which is a pita needless to say. thats what the mechanic thought was wrong with mine but it wasnt. i cant remember now what it was though.
__________________
-Kyle
Forasmuch then as Christ hath suffered for us in the flesh, arm yourselves likewise with the same mind: for he that hath suffered in the flesh hath ceased from sin; That he no longer should live the rest of his time in the flesh to the lusts of men, but to the will of God.
GOD IS A CONSUMING FIRE!!
outdoorfever is offline
Old 03-12-2004, 01:00 PM   #13 (permalink)
The oil cooler is mounted on the block in the same plane as your oil filter.
The hose that runs under the oil filter is connected to it.
I didn't remove any else on the truck except for metal bracket plate that allowed for access to oil cooler bolt from the wheel well.
The job was just real messy.
Old 03-21-2004, 03:57 PM   #14 (permalink)
do you have a part # per chance for the oil cooler seal? anyone? also am i correct in assuming that the oil cooler is the round thing on the same plane as the filter about 6" to the rear? i am working on a 90 4runner v6.
__________________
tuquoque is offline
Old 03-24-2004, 07:06 AM   #15 (permalink)
I don't think I kept my receipt because it was only a couple of bucks, but I will look again.
There are 2 gaskets. The dealership will have the breakdown.
One goes between the block and the cooler and the other is on the cooler itself.
We reinstalling the cooler make sure you align the cooler properly.
My truck had a bracket that aligned the cooler and also keeps it from turning when tightening.
__________________
1994 3.0 4Runner (Original Owner) 171K
2003 Jetta GLI
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
oil pan gasket ? cruisinforburgers 86-95 Trucks & 4Runners 11 09-25-2006 03:29 AM
oil pan gasket Localmotion 95.5-2004 Tacomas & 96-2002 4Runners 6 03-22-2006 07:30 PM
Oil pan - Gasket or NO gasket Dezertoyota 95.5-2004 Tacomas & 96-2002 4Runners 4 05-26-2005 04:03 AM
Oil pan gasket dropcivic 95.5-2004 Tacomas & 96-2002 4Runners 12 12-16-2003 01:09 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
