2nd Gen Articulation
Old 06-02-2004, 10:01 AM
mastacox's Avatar
Originally Posted by mt_goat
You will need to realign after doing any type of lift.
I'm aware of that, but it seems like a spacer for the upper ball joint will be especially bad for camber, are there pictures of one of these installed?
Old 06-02-2004, 02:50 PM
elripster's Avatar
I can post some tonight. There's been some healthy threads on these, if you search on them there are quite a few pics already up.
Are you concerned that the camber cannot be adjusted? So far as I'm aware all 60+ pair out there have been successfully aligned.
Frank
Old 06-02-2004, 02:55 PM
mastacox's Avatar
Frank
Very cool, I definitely will want a pair of them then... Maybe in about two weeks...
Old 06-03-2004, 05:39 PM
914runner's Avatar
hey mastacox, what is the part number for your shocks?
Thanks
Old 06-04-2004, 03:30 AM
  #25
dusty98's Avatar
How do you like the ride quality of the RSX shock?
Old 06-07-2004, 04:22 AM
  #26
Cebby's Avatar
Has anyone looked into the spring rates on 2WD torsion bars vs 4WD torsion bars? Is there any difference? What about 2WD pickups with a 4 cyl engine. They've got to be softer...
Old 06-07-2004, 06:07 AM
  #27
mastacox's Avatar
Thanks
I got RSX 17010 in the front, and RSX 17327 in back. I carefully drilled the bushings out to 5/8, other than that, they pretty much bolted right up.
Old 06-07-2004, 06:15 AM
  #28
mastacox's Avatar
The RSX is a very good shock for off road, it is relatively stiff for body roll and braking, but loosens slightly for a sudden jolt with a pot hole or say maybe 2 feet of air... I have tested them in a couple situations, mainly rockcrawling and hauling ass on rough dirt roads with air time, have come away impressed. I'll bet I'm going to really like them in the sand dunes, the damping assures I'll be able to drive fast...
Old 06-07-2004, 06:49 AM
  #29
wvuviv30's Avatar
I acctually think the 2WD torsion bars are shorter in length.
2WD Lenght - 1979-1983 is 35.250, 1984-1997 is 35.125", T100 is 34.75"
4WD Lenght - Pre 1993 T-100 is 35.87", 1993-1997 T100 and 1986-1997 4Runner/Pick-up is 41.874"
Fun Facts: Toyota Landcruiser has 2 sizes 45.731" and 47.62". A Nissan Pathfinder 4WD 1987-1997 has a lenght of 48.437".
The Longest is the Mitsubishi 4WD & Pick Up/Dodge & Raider both 1990-1995 lenghts are 53.812", and the Mitsubishi 4WD,Montero/Dodge & Raider 1990-1994 both 1990-1994 has a lenght of 53.800".
Now how hard would it be to adapt one of these sets of Totsion bars to a Toyota. Sway-A-Way's where 25-27.5mm in diameter... (all info from SAW)
Old 06-07-2004, 06:55 AM
  #30
Cebby's Avatar
Good tech WVUVIV!!!
Old 06-07-2004, 08:15 AM
  #31
elripster's Avatar
I looked into this years ago. The 4cylinder 4wd pickups have the smallest diameter torsion bars. All 4runners run the same bars regardless of engine size and it is the same as a V6 pickup. So, there is potential gain if you get the 4 cylinder pickup t-bars and put them in a V6 truck or better yet V6 4runner.
Frank
Old 06-23-2004, 06:58 PM
  #32
Scofco's Avatar
My contri.
Old 06-23-2004, 07:35 PM
  #33
Scarbro22's Avatar
Scofo is that tire cover the original one or did you buy that?? if so how much?
Old 06-23-2004, 08:36 PM
  #34
Scofco's Avatar
Came with my truck.
I'll be selling it soon on here.
It has a couple tiny tears and one hole up top from a tree branch
charlie_fong
09-27-2015 10:06 PM
Toys4parts
09-26-2015 01:56 PM
Project90
09-24-2015 11:40 PM
runnermedic
13
09-21-2015 05:20 PM
reallynotamechanic
09-11-2015 11:52 AM
Quick Reply: 2nd Gen Articulation
