2nd gen 4runner swaybar links
Old 08-24-2003, 04:49 PM
yotafool's Avatar
hey guys, im installing a 4" superlift and need to disconnect the anti swaybar links from the swaybars but im having quite a bit of trouble because the bolt which is 17mm just keeps turning when torque is applied, this occurs on both sides of the 4runner, thanks for any replies
Old 08-24-2003, 05:17 PM
Flygtenstein's Avatar
There is a small hex key hole in the center to keep the bolt still.
Properly executed, you hold the key and stand on the wrench to break it free. A box end wrench around the bolt and then the key in the middle should do the trick.
Old 08-24-2003, 05:51 PM
yotafool's Avatar
ok, thanx a lot and im gonna let one of them sit over night with some penatrating oil because its pretty bound up but the other one came right off after the advise
06-01-2021 01:51 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
ptb12
07-05-2015 01:49 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 2nd gen 4runner swaybar links
