2ND GEN 4Runner Check Engine Light - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-17-2005, 09:20 AM   #1 (permalink)
BMWSTOY's Avatar
Unhappy 2ND GEN 4Runner Check Engine Light
Good Day,
2 Problems, same issue?
Check engine light is Chilton # F12563 Air-Fuel Ratio Rich Malfunction. In the touble area is the Coolant temp sensor?
2nd problem: In the summer my A/C is super cold and then shuts off with no Check Engine light. I know some Toyota/Lexus' shut down the A/C system when other areas have problems, but do not let you know.
Could these 2 be related? I have owned this rig for 3 years now with out any other issues.
Thanks
__________________
2000 100UZJ. 4.7L V8 - no more 3.slow
1995 SR5 V6 4Runner - 118K. 3.0 3VZE. SOLD
31" Michelin LTX A/T's / Bilsteins / Downey HD Springs / K&N / OME Stabilizer
BMWSTOY is offline
Old 02-18-2005, 06:46 AM   #2 (permalink)
BMWSTOY's Avatar
According to the Chilton guide and the internet, the 3VZ-VE in my 2nd Gen runner does not have an MAF or a Coolant Temp Sensor. All my hoses past the air filter were spotless?
After clearing the code, it came back - Too Rich on the Air/Fuel mix. Now what?
__________________
BMWSTOY is offline
Old 02-18-2005, 07:06 AM   #3 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
I doubt the two are related....
A 3vze does not have a MAF, but rather has a VAFM (vane air flow meter.) It also does have a coolant temp sensor - thats what the ECT mod is predicated upon. I believe toyota calls it the "engine coolant temp sensor." As far as rich condition it could be anything that might restrict air flow or to add too much fuel....
TPS, fuel injectors, fuel pump, fuel pressure regulator, air filter, occlusions in the intake, loose vacuum line, etc are what comes to mind right now....
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 02-22-2005, 09:22 AM   #4 (permalink)
BMWSTOY's Avatar
Thanks.
Just got back from wheelin in the snow and reset the light. It was off for 4 days, no running probs and it came back on 10 miles from home - perhaps it does not like where I live? Back to diagnosing...
__________________
BMWSTOY is offline
Old 02-22-2005, 10:52 AM   #5 (permalink)
Doc279's Avatar
Quote:
Originally Posted by BMWSTOY
Thanks.
My CEL has been on for over a year - no problems encountered.
same crappy gas mileage as before it came on. No power problems
I believe that I need to replace the Oxygen sensor but the price has kept
me from doing it. Oh - the CEL periodically goes out and does not come back for several days. I'm just leaving it alone.
__________________
"Life's to short !!! Let's drink a couple - cold beers !
1985 4 runner - pretty much stock but it kicks butt stock !!!!!!!!
30" bridgestone duellers on black steelies.
More to come !
Doc279 is offline
Old 02-22-2005, 11:47 AM   #6 (permalink)
scott's Avatar
I'd put money on the CEL being a faulty O2 sensor. As for the AC, systems usually have a low pressure cut-off switch that kills the compressor when the line pressure gets too low. Have the wiring and the switch checked and/or get the freon system re-filled.
__________________
Scott H.
scott is offline
Tags
2004, 22, 24, 27, 4runner, 95, cel, check, checking, codes, engine, gen, light, malfunction, runner, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
03 4Runner Check engine light rany 03+ 4Runner/GX470, & 05+ Tacomas 12 09-24-2007 05:54 AM
2000 4runner check engine light breck_k 95.5-2004 Tacomas & 96-2002 4Runners 5 12-10-2005 06:54 PM
2nd gen check engine light fooddude 95.5-2004 Tacomas & 96-2002 4Runners 2 11-23-2003 01:50 PM
3rd gen 4runner check engine light on` mark_fit 95.5-2004 Tacomas & 96-2002 4Runners 9 10-01-2003 10:34 AM
2nd Gen Check Engine Light AlixTheRunner 95.5-2004 Tacomas & 96-2002 4Runners 11 02-25-2003 08:00 PM
2009 InternetBrands, Inc.
