2nd diff drop and suspension lift
Old 02-02-2005, 05:34 AM
Praufet's Avatar
I plan on making the lift described in this page
http://www.toyotasurf.asn.au/techsit...suspension.htm
And was just trying to gauge interest to see if anyone else wanted me to make the pieces. Otherwise its all for me
Old 02-02-2005, 05:26 PM
AW1090's Avatar
I'm interested....let me know what kinda cash it'll run
Old 02-02-2005, 05:38 PM
4Hummer's Avatar
Me too.. I had talked with NE about making me a custom ball joint spacer.. But I guess thats down the tube. (Hed probably make em outta plywood by the sounds of things.)
Let me know man SERIOUS
Old 02-02-2005, 07:13 PM
Praufet's Avatar
I'm going to be talking to some people this week. Anyone have any preferences? I was trying to decided between steel, aluminum, or rb lift material. Planning on using grade 8 bolts and maybe nylock nuts. Any requests, suggestions? I'll probably have some extra ball joint spacers if anyone is interested. Hopefully I can get this sorted fairly soon. I'll post pics once I get mine done and let you know prices.
Old 02-02-2005, 07:17 PM
AW1090's Avatar
That sounds good....I'm not sure on the type of material. I would think aluminum or HDPE over steel though. I'm not gonna need the sway spacers cause I took that mother off.
Old 02-02-2005, 08:04 PM
Marc P's Avatar
Why start from scratch?? Order spacers from Frank--that is what I did
http://www.sdori.com/SDORS%20spacer%20page.htm
Old 02-02-2005, 09:36 PM
AW1090's Avatar
I think the ones praufet is making are thicker....there's also the diff. drop spacers that I would like to use for my cv's sake.
Old 02-02-2005, 09:46 PM
Praufet's Avatar
Speaking of thickness, does anyone have a general preference?
Old 02-02-2005, 10:35 PM
KevyWevy's Avatar
i would love a diff drop, but what goes into the installation for that? there wasn't anything on the site about install, i thought the diff was as far down as it could go.
but yeah the 1.5" bj spacers from sdori is what i have
Old 02-02-2005, 11:51 PM
AW1090's Avatar
I was thinking 3", but correct me if that sounds crazy. Isn't that what thickness the guy used that we're getting this from.....what are your thoughts?
Old 02-03-2005, 12:31 AM
Praufet's Avatar
In the article I linked to the guy use 25mm thick Al. That's about 1" for those of you unfamiliar with the metric system. Honestly I just have to see what thickness of Al I can find. Going home this weekend so hopefully a bigger city will have more options. I think 3" would be a bit thick. I could look at the front suspension and try and find out the max you could fit, but I think if you went too big, you could end up needing a longer spring among other issues. Also in the article the guy used grade 5 bolts for the diff spacer. I was think grade 8 because thats what roger used in his 3rd gen diff drop kit.
Old 02-03-2005, 12:35 AM
AW1090's Avatar
sorry, just read the top of the article and glanced at the rest. I'm new to all of this, but have been learning a ton......I haven't looked at the front suspension real close, but I assumed that's what the diff. drop was for is the fact that you're going over an inch and a half. If not than why even worry about the diff. drop?
Old 02-03-2005, 04:41 AM
Marc P's Avatar
Good luck with the alignment if you go bigger than 1.5 on the ball joint spacers.
Old 02-03-2005, 06:10 AM
Doc279's Avatar
I'd be interested !!! Where do you get the rear coil spring spacer ?
1" or 25 mm is great for the differtial drop. I've not done the ball joint spacers due to the cv shaft angle - even though I have manual hubs.
Now with the differtial spacer - I might just do this.
Cost ? I would use grade 8 hardware no matter what.
Old 02-03-2005, 08:33 AM
Praufet's Avatar
I'd end up making all of it, rear coil spacers, ball joints, and diff drop. Sdori says they have a patent pending on balljoint spacers, but that article shows obvious prior art so.... Not to bash them.
Old 02-03-2005, 08:59 AM
Randomness's Avatar
Check out the fender flares on those Surfs...wish we had those here for 2nd gens sorry off topic
Old 02-03-2005, 09:09 AM
Praufet's Avatar
I hear that
Old 02-03-2005, 09:19 AM
KevyWevy's Avatar
i second that. but i also don't see what the point is of you guys making the BJ spacers, if there are already proven bj spacers out there? probably just as expensive an they're actually machined.
but i would still like to know how he did the diff drop, becaue i always thought they were pretty much impossible on the 2nd gens.
Old 02-08-2005, 06:55 PM
Yamaha+Toyota=Fun's Avatar
Im interested in the diff drop.
Old 02-08-2005, 07:40 PM
KevyWevy's Avatar
yeah, i would really like one as well, or at least see some info on the instal. i guess i could go take my skid plate off and look, but that takes too long and its cold out!!
Quick Reply: 2nd diff drop and suspension lift
