22RE To 22RET swap
Old 04-02-2003, 05:38 PM
Mudd Runna's Avatar
22RE To 22RET swap
I've got an 88 4Runner w/22RE in it...I just found out that I've got a head gasket blown....I know I don't need to replace to whole motor but I was thinking about it....Does anyone know if I can just drop in a 22RET without any other mods?
Old 04-02-2003, 05:46 PM
Bean's Avatar
Fuel injected? (can't remember) If so you'll probably need to swap the computers but I would imagine the wiring harness would be close.
For my money - if you happy with the performance fix it. Plenty of resourses available to help you do it yourself. If you really need more power and this happens to be the right excuse - look for a newer 2.7L or 3.4 from a Taco/Runner. It'll cost more but still be easier than a none toy engine.
Old 04-02-2003, 08:02 PM
rj
rj's Avatar
22ret
Mudd Runna, I mentioned on a previous post that I was thinking of trading a tranny I have for a 22ret w/tranny. The 22ret and tranny both need rebuilt. I'm not going to pursue it. If it's something you'd be interested in checking out I'll try to get the two you together. Let me know. rj
Old 04-02-2003, 09:14 PM
Duffdog's Avatar
hey ya know what...
i had a 90 yoter and i wanted to change the engine from a 22re to a 22rte and the foreman said ya gots ta change everything including the wiring harness and the ECU. And for what??? only 40HP?? thats bogus in my opinion-- i would modify the internals of my 22re with some titanium con-rods, high compression heads, bigger valves, a big camshaft, knife-edged crank, aluminum flywheel, ported-polished head and a larger diameter throttle body. After all those things, youll waste pretty much any 4 cylinder 4runner out there.
Tim
Old 04-02-2003, 10:06 PM
Shane's Avatar
...and enough money that you could have just swapped in a 4.3 V6 in there instead.
Old 04-03-2003, 07:34 AM
Mudd Runna's Avatar
O.k...So what would I need to do a 4.3 swap?
Old 04-04-2003, 01:50 PM
Mudd Runna's Avatar
rj
O.k...let me see if I understand your thread right....You have a 22RET motor and tranny you will trade for another tranny? Am I lost?
Old 04-04-2003, 01:59 PM
rj
rj's Avatar
I lost ya!
I know a guy that is going to pull out his 22ret out of his 86 and replacing it w/a V8. Other than putting the two of you together I'm not involved. rj
Old 04-04-2003, 02:03 PM
Mudd Runna's Avatar
Ah Ha!!! lol....Cool...my email addy is shieldcrusher2000@yahoo.com tell him to email me....Thanks man...
Old 04-04-2003, 04:58 PM
Eighty7ToyTruck's Avatar
dood, do a efi 4.3 swap, boost the compression some, and then send me detailed instructions so i can pull my 22rte and put a 4.3 in, alright? lol
Old 04-04-2003, 05:04 PM
Mudd Runna's Avatar
wait a minute...Did that guy mean a 3.4L swap and not a 4.3? If so...I'm feeling a little dumb for not catching it...lol
Old 04-04-2003, 09:57 PM
Shane's Avatar
3.4 is Toy, 4.3 is Chevy... whatever engine you use in a swap you need the same stuff, all the wiring and the computer. About the only other thing you need is any necessary adapters and some fab skills.
Old 04-05-2003, 05:31 AM
Skydigger's Avatar
Yeah. I'd either go with a full swap in of a 4.3 or 3.4 or just rebuild your 22RE. JMHO but it's probably not worth swapping in a Turbo for what you get. They are kind of cool but you're probably after torque not HP if you're wheeling it.
Good luck,
Warren
Old 04-05-2003, 06:59 AM
44Runner's Avatar
THe easiest swap would be a healthy TBI 4.3. The wiring is much easier than the 3.4 or the MPI 4.3...
Old 04-05-2003, 08:15 AM
Mudd Runna's Avatar
You know....I think that's what I'm still going to do is just beef the he** out of my 22RE....I guess whatever I can...Cam, headers, high flow exhaust and anything else I can think of....I suppose now would be a good time to do it since I'm going to have the engine apart to do my head job.....
mskalmus
05-28-2017 07:51 AM
coleypull15
11-03-2015 07:41 AM
steve miller
10-10-2015 01:40 AM
deepmarsh
08-06-2015 03:44 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22RE To 22RET swap
