Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
I have a 2wd 1991 Toyota truck. It has 14 X 5 in wheels, and the stock tire size is 195/75 14. At tirerack.com, they say I can run 205/75 14 on them. Will 205s fit? Well?
Thanks.
__________________
1990 Toyota Pickup 2WD [Dark Gray Metallic (179)] --Short bed/Std Cab, Amsoil panel filter + deckplate mod, diy ground kit, autometer tach, L46 4 speed/22RE, 195/75-14 Michelin LTX M/S 1984 Mazda RX-7 GSL-SE [VG Beige] --K&N Panel Filter, RB cat-back, 13" Grant GT wheel, spare tire/jack delete 1983 Mazda RX-7 [Dover White] --302 H.O./T5 swap in progress |
| Sponsored Links |
#2 (permalink) |
Should be fine. The 205's are only a total of 1/2" (1/4" per side)wider and not even 5/8" larger diameter overall (25.5" vs 26.1"). Check the existing clearances to verify, but it is a very minor change.
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#3 (permalink) |
I have a 1993 2wd truck, and the truck was given to me with 205 tires on the 14" rim. I have had no problems with it since i got the truck back in 2001. Go for it!
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ProComp 5in lift for the FJ. | Armi'sFJ | FJ Cruiser | 0 | 09-08-2006 05:25 PM |
| 15x10 Center Line Wheels 3.5in backspacing 6on5 | russkrs | Axles/Suspensions/Tires/Wheels | 1 | 03-28-2006 02:00 PM |
| 88 4runner 4.3 tbi,sas,400,205,exc body | red83 | Vehicles - Trailers (Complete) | 12 | 02-14-2006 03:23 PM |
| Minnesota Trooper writes a ticket for 205 miles per hour! | jrallan26 | Off Topic Talk | 14 | 09-22-2004 08:07 AM |
| 3rd Gen - Can You Fit 6.5in Speakers In Rear Door? | Vato Loco | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 08-09-2004 10:52 PM |
