2002 4Runner w/99 springs
Old 09-27-2007, 12:45 PM
Atwater27's Avatar
If I put the springs from a 99 highlander on my 02 SR5 is 1" all I will get? Is that just with the 96-98 years? Will I get more than that on the 02? If I put these on should I still use a spacer for the rear and which one should I use?
Thanks
Craig
Old 09-27-2007, 12:51 PM
cackalak han's Avatar
Yes, I believe 1" is all you'll gain, so nothing really at all.
Man, going through all that trouble of putting new springs in, I'd just opt for Tundra springs + OME. Do it right the first time.
Old 09-27-2007, 12:55 PM
Atwater27's Avatar
How much of a lift would this give me? What would the parts cost on this left?
Old 09-27-2007, 01:25 PM
Rock Slide's Avatar
Check out Sonoran Steel for the Tundra/OME lift kits:
http://sonoransteel.com/store_complete_liftkits.html
Otherwise, you can piece a used kit together yourself.
I purchased the SS 7.1 kit from Steve and I've got it installed on my '02 4Runner. Check out my Profile in my sig to see pictures of it installed. I gained 2.5" in the front and 3.0" in the rear. (my rear was sagging .5")
Steve's kits are top notch.
Old 09-27-2007, 02:15 PM
One_96TR4's Avatar
I thought that you would get closer to 1.5-2" of lift with the 99 coils seeing how the 01-02'a were the "low rider" years. I still wouldn't go that route though I don't think it's worth the trouble. Another option that seems to work around here is the toytec 3inch lift. I believe they have other options as well. checkout toytec.com
Old 09-27-2007, 03:03 PM
SOAZtim's Avatar
YEP. My lowrider 01 got about 2 from the perf products 1 inch lift springs...
Old 09-27-2007, 03:04 PM
skjos's Avatar
I did the old school OME lift on my '02.
881 with n91sc
890 with n86
2.5" in front
3" in back
$617 + $55 shipping + $15 coil compressor + $50 strut assembly = $737 total
If I had the cash I would've gone SS 7.1, but I put the money saved into rims and tires.
SS 7.1
1161.50 + ($55 + $15 +$50) = 1281.50
Old 09-27-2007, 03:23 PM
Originally Posted by skjos
SS 7.1
A little bit cheaper with the non-wuss version =
$1161.50 + $55/shipping + $0 for rented spring compressor + $0 DIY = $1,216.50
You can call trdparts4u.com and get the stuff from them, too. I believe the springs and struts/shocks will run you about $700.
Old 09-28-2007, 10:11 AM
skjos's Avatar
I wish I could have compressed the 881 coils with the spring compressor I rented. It nearly killed my impact wrench just to get the stock top plates off the old strut. There would have been no way to compress the 881's to fit my new struts. Therefore I wussed and had Billy Bob's Offroad assemble the new struts.
$0 dollars for the rented spring compressor, man I wish your rental shop was in my neighborhood.
Old 09-28-2007, 10:32 AM
Actually, I'd probably take it to a shop, too. The stock springs were scarey enough to compress...
Autozone and Checker's rents for free.
Old 09-28-2007, 12:23 PM
Nate08's Avatar
Just wanted to second this.
Old 09-28-2007, 12:27 PM
emptypockets's Avatar
From what I've read, you will get more than 1" from the 99 coils...more like 2". I'll second some other ideas in this post that you might as well go the Tundra/OME or Tundra/LC route while you're at it.
Old 10-11-2008, 06:46 PM
Go4Lo's Avatar
Hey all. Brand new member today, Sorry if im off the subject but i have a couple questions. I went in to get an estimate about a lift for my 01 4runner. les swab and the dealership. the dealership was surprisingly cheaper who would you reccomend? Also les swab hated on BF G's they dont sell them, however l like the looks of them. what do you think?
Old 10-11-2008, 09:07 PM
One_96TR4's Avatar
If the dealer is cheaper then I see no reason not to go with them.
Road Bull
10-10-2015 04:55 PM
rushw
07-18-2015 01:46 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: 2002 4Runner w/99 springs
