2" sus. lift in the front...should i drop the diff?
well i want to do the manual hub conversion just because of all the bad things ive heard about the ADD's. so i may just do a 2'' coilover that i can adjust later and do a 2 and a half in AAL in the rear. and then when i get the conversion i will do the shackels in the rear and crank up the front to 3 inches.
I have a 2 1/2" spacer in the front and I have a diff drop kit installed. I now have a significant vibration in the front at around 25 mph and I can feel something similar at around 45 mph. It feels like the cv angle is off and feels like something is binding. I am wondering if I really needed the diff drop or can I take the drop kit off and do you think it would put too much angle on the cv's or do you think I would be alright. Can I do this w/o messing up the alignment.
#25
#26
#28
Originally Posted by GRNTACO
So you want to take the diff. drop out because of the vibration you feel? Taking the diff drop out won't mess up the alignment but may cause damage to your CV's. Did you lift the rear and if so how much??
#30
the differential is supported by 3 mounts. the diff drop kits only lower the front 2, thus the tilted diff and apparently "there is a bearing in there that gets all screwed up"
#31
#33
So is it possible to add a drop for the 3rd mount location? in al lhonesty, I haven;t looked at it....yet. I imagine doing this would change the driveline angle a bit but it doesn't seem like it would be enough to make much difference.
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
coffey50
07-28-2015 10:55 AM
Steven.m.paulk
07-24-2015 01:44 PM
scottyg486
07-19-2015 05:34 PM
