2" body lift write-ups for 2000-2002??
Anyone out there have a 2" body lift write-up for a 2000-2002 4Runner??
Chris (ravencr) was kind enough to provide a write-up for a 1" RB BL, but that doesn't directly apply since 2"+ BL's affect steering and tranny linkage, that 1" BL's don't.
I'm inches away from going with a 1½" Roger Brown, but it seems the more I read about +1" BL's, the more gatcha's I run into. For example, one site mentions not being able to access the spare tire winch with the crank handle after a 2" body lift because the holes are misaligned afterward. Anyone know if that is true?? (I know the rear bumper moves with the body, but I would think that the spare winch is also mounted the to body's under carriage... maybe I'm wrong??).
My '01 body bolts appear to thread directly into the prefab'd/threaded mounting bracket (no separate nut on the underside). Do the bolts supplied in the RB BL also thread directly into these prefab/threaded mounting brackets, or do they need to be drill out?? If a drill out is needed, I like to go with grade 8 bolts. Anyone know what size (dia.) and length come with a 2" RB BL??
I also read the front bumper mounts are a bit different on 2000-2002, so the frot bumper brackets available from Roger need to be modified a bit.
Just wanna make sure I've got a of my base covered before I get into this....
Re: 2" body lift write-ups for 2000-2002??
Brian
If I can find it in a search i'll post it here.
You shouldn't have to drill out anything. Just take the OEM lock washer things off the top of the bolts to put on your new bolts from RB.
Bumper mounts will be made according to amount of lift. They work fine no problem.
Any other questions, just email me and I'll be happy to help.
I will say this, it is easier to take the whole steering section off the spline and mark both pieces where you took it off, loosen the bottom bolt and then take it apart on the shop table and put in the spacer, then put it back on lining up the spline
Brian
I just did a 3inch on a dakota today. I know it is different from the 4 runner but they are alike in many ways. on the spare tire thing the holes don't match up anymore but we were still able to turn the crank at a angle just fine( i would guess a 2inch would be okay) the bolts did go right into the stock mounts. i don't think the spare whinch is mounted to the body it is on the frame. good luck. redtoy92
With a 2 inch, the wholes dont line up...BUT you can still lower it with a 1/2 drive socket extender just inserting it behind the bumper where the crank bar would come through. Its really easy to do especially when you have a 2 inch BL.
As far as instructions and parts...Roger includes everything you need to do it and its all high quality stuff. There isnt really a difference between installing a 1inch and a 2 inch. You have to do the same things, steering spacer and trans linkage.
If you havent read it yet, here is AdamF's writeup VIA RogerBrown which is what i followed to do my 2inch BL:
http://4crawler.cruiserpages.com/4x4...er/index.shtml
Bumper mounts have to be modified? I have a 96 so I cant testify to that...
Have you guys had any probs with the 2" BL? I read 4crawlers page (What you have to replace) is all that necessary? or should I just go with a 1" BL and not worry about it?
No problems!
Took off lower fan shroud, didn't move radiator, used the extra bumper mounts, undid the battery harness, it was tight and redid it after the lift, I used the steering extension but didn't have to mess with tranny linkage. Any other questions PM me.
Hope this helps!
Brian
yeah i have a 1.5 inch rb body lift. after the spare tire holes didn't line up, so when i got my new trailer hitch, i had them do a little work to it, and now they line up and i can use the factory tools.
i had the lower radiator fan shroud issue too. it had to go, and i've been fine without it. i did't bother lowering the radiator, it's fine. so other than the steering column extension and bumper brackets, that was it for my body lift.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
