1981 SR5 Spare Removal?
tire
Greetings There should be a long rod behind the seat, attached to back cab wall, with a clip. Take that and go to the back of the truck, above the license plate there is a hole to put the rod in ( sounds kinky ) and start cranking. This will lower the tire, crawl under and lift up on the tire, fiddle with the chain and slide out with the spare. Repeat to get the spare back to where it belongs. hope this helps
coffey50
07-28-2015 10:55 AM
sabine
07-18-2015 03:59 PM
crashburnoveride
07-10-2015 06:39 AM
