15" rims on a 96 limited?
I found a set of 15" 2nd gen 4runner wheels with bfg muds on them for a decent price locally. Will a 15" rim fit on a 3rd gen 4runner. if i remember correctly a 15" rim is to small due to the size of the brakes on the limiteds. Just wanting to get confirmation on this, thanks.
thanks for the replies. by the time i bought these tires/rims and then swapped calipers, it would probably be cheaper and easier to just buy muds for the rims i have now. thanks again
FWIW I was going to do the same thing. I had a set of 15" wheels here that wouldn't fit, and I even had a set of Tacoma 15" calipers off a set of junked Taco rear ends I bought. The Taco brakes will bolt up fine, but they will require a different brake line -for some reason they have a different end where it goes into the caliper??
Anyways, I ended up not going thru with the mod because I didn't feel right going UP in tire size and DOWN in brake size.
primordialbeast117
12-19-2015 12:23 PM
Cycles
09-29-2015 06:37 AM
charlie_fong
09-27-2015 10:06 PM
