12.50" wide tires on stock wheels + wheel spacer?
Old Oct 5, 2004 | 06:47 PM
BajaRunner's Avatar
I dont have enough money for the rims I want, so Im just going to go ahead and get the new tires.
Im getting 305/70/16 so they are 12.50" wide.
Obviously with the stock wheel setup, I'll have clearance problems with the a-arms.
Right now with my 10.50" tires I have 1" clearance. With the 12.50, I will have 1" added to each side. So, Im thinking I need at least a 1/2" wheel spacer.
I noticed all the bolt on wheel spacers are like $80+ for a pair.
Since this will just be temporary, could I just buy the "slip-on" 1/2" spacers like the ones below, and have no problems?
Or shoudl I go ahead and just buy some 1" bolt on ones? I like the Marlin Crawler ones, but, I cant understand how to order them?!?!? How do I order through marlin?
Thanks in advance
Old Oct 5, 2004 | 07:04 PM
dragr1's Avatar
Thanks in advance
Stay away from the slip on spacers-they will cause horrible vibrations from the front end. I ran them for a week and took them off.
Old Oct 5, 2004 | 07:48 PM
Bigkahuna808's Avatar
Im going throgh the same dillema, but on wider rims.
Old Oct 5, 2004 | 08:33 PM
BajaRunner's Avatar
Yeah, I was htinking about just getting the more expensive ones I guess.
All I can find are 1.5" spacers. Will those just look silly as hell with the already wide tires of 12.50" ??!!!
Well, I guess that will work until I get my rims.
Old Oct 5, 2004 | 08:42 PM
superjoe83's Avatar
12.50" tires on a 7" wheel is pushing it, if you do it i would recommend to run them at a lower pressure than you normally would to help the tire flatten out and not wear in the middle
Old Oct 5, 2004 | 09:06 PM
BajaRunner's Avatar
Good point!!!!
I was wondeirng about that as well.
Thanks for the input.
Old Oct 5, 2004 | 09:42 PM
Im gonna try and pick them up all Allprooffroad.com
Or if ym homeboy at 4wheel parts got them.
Old Oct 5, 2004 | 10:12 PM
4RUNR's Avatar
Guest
How exactly would this happen with a lugcentric wheel? Your wheel studs moved?
Old Oct 5, 2004 | 10:43 PM
Im planning on bolt ons
Flying91
45
Apr 11, 2024 04:39 PM
94whiterunner
9
Sep 22, 2015 07:28 PM
DrZero
Jul 13, 2015 09:59 AM
Yotoder865
Jul 9, 2015 07:51 PM
