$100+ to Whoever can help me w/ 4wd issue!! C'mon Electrical Gurus!
Here'e the scoop, I have a '99 LTD 4runner with the super fancy, pushy button AWD feature. (Can you tel I'm frustrated.)
In a nut shell no matter what position the controls are in, all I get is blinky, blinky from the status display (4 green + 1 orange LEDs). When I move the lever they stop for 3 seconds before blinking again.
After trying all the fix its I found around here, I ended up replacing 1 sensor on the tranfer case, and one solonoid from front ADD system in the engine bay on left fender. No dice.
I finally took it to my friend's dad who the local dealer's 4wd expert (over 15 some odd years experience), so I know I wouldn't get screwed. Long story short after looking it over for a day and a half he deduced that all sensors, solonoids, wiring (yup he tested every wire), and the motor that engages the front driveline from the transfer case, and the ADD sytem was working perfectly. He tried a bunch of tricks that he got after calling and talking to some Yota engineers. Nothing worked. So he deduced that the problem must lie in the 4wd ECU.
I went ahead and found the 4wd ECU one at a salvage yard in Oregon, and I went ahead and bought a new Elocker ECU (I'm guessing thats what it is, its the black module under the left kick panel that says 4wd). I just got both today and just put them in, and gues what, same thing.
Right now I have the battery cable unplugged in a vain attempt to try resetting the ECU. I'm skeptical to say the least.
Now the $REWARD$ part. Here's the deal I'm at wits end with this thing. I'm going to call up my friend tomorrow to see if he has any other ideas, but this ECU thing seemed like his last posible thought. So my question is, is there any kind of electrical magic to make the transfer case motor, the ADD actuator motor, and Locker do their jobs by moving the 4wd lever AND some after market switches. Basically bypass all the factory BS. If someone can come up with a system that works, I will gladly pay them AT LEAST $100, price is definitely flexible. I will definitley make it worth your time.
I'm comfortable with most wiring, but this is just beyond my grasp, especially since I don't have any diagrams to go off of.
Somebody
Somebody
Somebody
Somebody
I remember seeing this problem before but I don't remember the solution right offhand....I will try to find for you.
Somebody
Somebody
Another gentlemen had a similar problem and his stealer replaced (2) things, but one of them took care of the problem.
Part that did not address his problem: Actuator on tranny 36410-35051
Part that fix his problem: Front differential actuator 41400-35020
We also both have 99 LTD 4WD Runners so this part numbers should apply to your 99. The bad thing is that what to try first. Here's a link to the post where I reported this problem.
http://www.4x4wire.com/forums/showfl...ev=#Post462226
Good luck and let us know the outcome out of this.
MTL_4runner: Where can I get a good deal on a factory service manual?? How much should I expect to spend?? Thanks for the advice.
I read that link when I first found the problem, so that is kind of the direction I went in. I found one faulty switch on transfer case motor, and a bad vacuum solonoid on the front, which I replaced. Then the dealer checked every sensor and he said they all passed specs.
You have me curious though, what exactly was the front actuator he was talking about? Was it the sensor or a motor?? I'd be tempted to buy them and try them out. How much did they cost??
Thanks for the input!!
Originally Posted by CTapia
Ok, I'll take a stab at it... I had a similar problem not so long ago. In my particular situation, a transfer case indicator switch went bad. The stealer replaced it, part number: 84222-35080. This took care of my problem.
Nobody looks at page 2 over the weekends.
OK, for a FSM, try ebay. They come up for sale pretty often.
The actuator is not a sensor, it is the motor itself.
You can take it out and apply power to test it manually.
I added push button 4wd when I installed an MC09 on my 4Runner. The donor transfer case that I stole the shift fork, syncros,...ect from was off a limited 4Runner that the dealership had replaced by warranty. Well what happened on this bad transfer case was a throwen brush on the motor that moves the shift fork which caused the transfer case to be inbetween modes. I reseated the brush and it now works fine. The first thing I would try is to unplug the motor and apply 12 volts to it and see if works
Today I just got the dealer to give me color print outs of the whole 4wd system, (until I can get a FSM) so I guess I'll just have to start double checking everything he already did.
Thanks for the help.
Keep the ideas coming.
I'm assuming that you're talking about the motor that moves the fork that engages the front driveline into 2wd or 4wd? It sits on the lower left back half of the transfer case? If that is what you're talking about then the dealer already did just that. He said that he could manually make it shift in and out of 2wd and 4wd by applying jumpers to to the motor itself, plus I even got a whole "new" motor from a salvage yard that didn't help. Or are you talking about something else??
As for the item that the dealer replaced on my truck, it was covered under my extended warranty, therefore I don't know the cost of it.
Zuke79
02-09-2011 08:56 AM
Hollywood
16
04-30-2007 04:31 AM
3641035051, 4140035020, 4runner, 4wd, 8422235080, 99, actuator, bypass, factory, fork, part, shift, switch, toyota, w4wd
