01 tacoma tranny problem (5spd)
Old 12-06-2003, 06:54 PM
GoudyMan's Avatar
I have an 01 tacoma 4x4 (3.4l 5spd) TRD it only has 30k miles on it. So here is the problem:
When I shift from first to second (also downshift 3 to 2), it often doesn't want to go into second gear. Sometimes if I double clutch it is ok, but other times it still gives me trouble. Also, if I let the clutch out too far while in nuetral and rolling (double clutching) then there is a knocking sound and I can feel it on the floor of the car. Also, recently it does not want to come out of first gear every now and then.
I took it in to Toyota and told them I thought the clutch needed to be adjusted, but they looked at it and said it was fine. I told them about how it wont go into second gear, but the mechanic just put on the notes that the clutch is starting to show a little wear. (Which should not be the problem if it is properly adjusted!)???
Also, it is never a smooth shift, but some times it is harder then others!! sometimes it grinds going into first also!
I am not hard on the tranny but I have only owned the truck for 2500 miles now. I have driven manuals for a while and never had this problem. It seems from what I could find on the web it could be the syncros. If anybody could fill me in on whats causing this and what it takes to fix, that would help a ton. Also, any idea what something like this costs to fix? And if you know if it is something that should be covered on the warranty??
Thanks.
Old 12-06-2003, 09:28 PM
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Sounds like the synchros on second gear are going bad and not slowing the gear down enough for you to shift smoothly. I had an '01 Tacoma 5spd with no shifting problems what so ever. You're right on track with your theory and the repair should be covered under the powertrain warranty and the 3/36 too. Get it to the stealer b/c if 2nd is going bad, the others will probably begin to follow suit. Also, don't let them tell you this is normal or not covered because neither is true.
Old 12-07-2003, 08:08 AM
My 99 Taco 5-speed lost first gear at 58,000 miles! Pissed me off so bad, I traded it in. Toyta put a crappy manual transmission in those trucks!
Old 12-07-2003, 08:15 AM
44Runner's Avatar
My 99 4Runner still shifts like it did the day it came off the lot and it has about that mileage...
Old 12-07-2003, 09:14 AM
As I recall, 4runners are built in Japan and Tacoma's are built in Fremont Ca., right?
Old 12-07-2003, 09:21 AM
Webshot, you're correct. What does that say about the quality of the two different manufacturing plants?
Old 12-07-2003, 09:27 AM
rwmorrisonjr,
You saw right where I was going with that! LOL!
Now you know why I traded my 99 Tacoma in for a 2003 4runner!
Old 12-07-2003, 09:33 AM
I also bought my wife a 2003 Rav4 "Made in Japan!"
Old 12-07-2003, 10:15 AM
Darx's Avatar
I have an '01 Taco with 70k on it, I drive a lot of freeway, and I have no shifting problems and have yet to get any powertrain work done. The only gear I sometimes can't get is reverse so I have to roll the truck back or bump it forward a couple inches then try again.
Old 12-07-2003, 10:18 AM
Darx, that's also a synchro problem since you shouldn't have to move the truck or double clutch it to shift into Reverse. After all, you're not driving am 10-wheeler or a Big Three vehicle!
Old 12-07-2003, 10:41 AM
kyle_22r's Avatar
uh oh...sounds like toyota brought back the L50...
Old 12-07-2003, 10:44 AM
Darx's Avatar
Oh. I just thought it was normal because my '97 Taco was like that too. It just wont go in reverse all the time then I roll it an inch or so forwards or backwards and it would go. Well, maybe I'll tell the dealer next time in about it but it's sporadic thing.
CTB
CTB's Avatar
Is it really a problem? I mean, sometimes I can't shift all the way into reverse, so I have to inch it forward just a little, and then I can get into reverse no problem. Is that just from the synchros not lining up? I've always taken that for normal operation.
Old 12-07-2003, 10:45 AM
44Runner's Avatar
The only problem that I have ever heard of before with these trannies is the 3rd gear problem. I myself have experienced that many times. 3rd gear has always been harder to grab, but I never have the problem unless I am going like a bat out of hell...
Old 12-07-2003, 10:48 AM
This may be normal actually. Next time instead of rolling anywhere, just try letting the clutch out and press it back in again while in nuetral after starting the engine. This sometimes worked for me after first starting the engine.
Old 12-07-2003, 10:58 AM
Please explain what the L50 is? Sounds interesting.
Old 12-07-2003, 11:32 AM
44Runner's Avatar
Its a notoriously weak toyota transmission used in older trucks...
Old 12-07-2003, 01:05 PM
kyle_22r's Avatar
it was used in '81 and '82 i believe...all 3 of the 5 speeds from '81-84(L50, L52, G52) are all known to be weak, but i think the L50 is the most notorious
first 5th gear goes, then 3rd, then 1st, then 2nd, and all you're left with is 4th to get you home
Old 12-07-2003, 01:28 PM
GoudyMan's Avatar
thanks guys... i will have the dealer fix it on Monday.
Old 12-08-2003, 03:19 PM
GoudyMan's Avatar
They are trying to tell me it is normal wear....... i was like, you have to be kidding me, its not going into gear... how is that normal?? if the clutch is worn it will still go into gear!! I HATE DEALERS....
Quick Reply: 01 tacoma tranny problem (5spd)
