Stanz's 1986 4Runner
Old 04-25-2016, 08:16 PM
  #241
84 yota dude's Avatar
Heck yeah! Junkyard parts score?!
Old 05-01-2016, 09:23 AM
  #242
CamTom12's Avatar
Very cool!
Old 05-04-2016, 03:10 PM
  #243
stanz's Avatar
Today's arrival. Going in shortly
Old 05-25-2016, 06:55 PM
  #244
stanz's Avatar
The FJ Cruiser mirror install is finally happening! Mike @ District Fab built the light brackets for the PIAA fog lights and is cutting into the doors
Finished product. Now onto the wiring!
Old 06-19-2016, 11:21 PM
  #245
stanz's Avatar
FJ Cruiser mirror lights are wired up! Write up coming shortly
<br >
<br >
Old 06-20-2016, 08:07 AM
  #246
Where did you end up buying the mirrors?
Old 06-20-2016, 12:42 PM
  #247
stanz's Avatar
eBay. Aftermarket.
Old 06-20-2016, 11:24 PM
  #248
stanz's Avatar
This past weekend's progress on the FJC mirror install...
I got the defrost grids installed and wired to the mirror harness and the fog lights fully wired. I ran out of time to run power to the mirror harness and switch for power control and defrost.
Some progress pics:
Defrost grids:
<br >
Defrost grid on the glass:
<br >
Glass frame prepped for gluing the glass back on:
<br >
Glass installed frame with wire harness attached - I reused the marker light wiring for the defrost:
<br >
Old 06-21-2016, 07:03 AM
  #249
Seriously love how you add all these modern day creature comforts to make it an even nicer daily driver!
Old 08-17-2016, 07:48 AM
  #250
ewong's Avatar
WOW
Some Build Up
(subscribing)
The 86? I scrounged my rear seat belts from, did not have the seat belt pocket things
Old 08-17-2016, 04:27 PM
  #251
ewong's Avatar
Loving this thread....
I see you have the Turbo thermostat outlet... I run an aftermarket water temp through that.
Also - ref $2K for the AC...
In 1989 (new) I had the dealer install the OEM AC - it was $700 installed. It uses the OEM parts (as far as I can tell)
Thats $1400 in todays dollars.
And thats without having to make custom hoses etc.
That being said - after having converted my R12 over to R134, I think you could have tackled this yourself given the other work you have shown on this thread.
That front condenser, looks like its a parallel flow.
Any idea on a part number for that unit?
Old 08-17-2016, 04:36 PM
  #252
stanz's Avatar
Thanks! Unfortunately my 60+ hour job prompts me to outsource certain larger projects if I want them done timely. I left it up to the shop to source all of the parts so I have no idea on the PN.
As for the thermostat housing I don't know turbo from non-turbo. It was on there when I bought it.
Old 08-18-2016, 10:36 AM
  #253
Reluctanse's Avatar
That FJ Cruiser mirror retrofit might be one of the coolest mod's I've seen anyone do on these trucks! Got my wheels grinding for sure....
Old 08-22-2016, 01:05 PM
  #254
stanz's Avatar
This weekend's update: replaced the Idle Air Control Valve (IACV).
Old 10-08-2016, 01:52 PM
  #255
stanz's Avatar
Fresh out of District Fab R&D. I wasn't happy with any of the options available on the market for mounting the ARB awning to round Yakima bars. After recent woes with wind and rooftop accessories, I designed these to be super heavy duty.
The following users liked this post:
runner88 (01-05-2020)
Old 10-08-2016, 05:23 PM
  #256
Nice!
Old 10-11-2016, 12:04 AM
  #257
stanz's Avatar
More good stuff in the works. I've been keeping Mike at District Fab busy...
Custom diamond plate rocker guards:
Rocker guards sprayed with bed liner and ready for install:
Custom upper door panel pads (Tacoma weather strip rail welded on inside lip to allow for new, replaceable window rubber). Custom door panels in the works using these as the top:
Old 01-18-2017, 04:10 PM
  #258
sportinh2o's Avatar
Hey there, I was wondering how your interior was holding up after the redo? I am almost to the point of getting out from under my 4Runner and concentrating on the inside.
Any thing you would have done differently?
Old 01-03-2020, 11:42 PM
  #259
stanz's Avatar
interior is holding up great. Wouldn’t change a thing.
Old 01-03-2020, 11:45 PM
  #260
stanz's Avatar
Been a while since my last post, lots of exciting developments...
Quick Reply: Stanz's 1986 4Runner
