OrRunner's 1987 4Runner Build-Up Thread
#81
Also, Just picked up a set of 31x10.5x15 maxxis bighorns with 95% tread for 225.00 with rims.....I thought this was a great deal, have not ran them before, but so far, I like them, very quite compared to the others I had, can't wait to get them up on the trails. Will post pics soon!
#82
yep, I'm a slacker. Big horns are on, got some 7" hid driving lights mounted up. Just placed my order for:
IFS eliminator kit 4"
rear classic 5"
Long spline driveline kit
Thanks Scotty @ AOR
http://www.addictedoffroad.com/index...=index&cPath=2
Have the rear locker, still need to save for 5:29's, going to be running 35 10.50 15 if I can find some I like otherwise I will go 12.50
going to try and start the axle rebuild in the next 2 weeks. Then the sas will follow about 2 weeks after that.
Will try and post some pics when work starts
rear classic 5"
Thanks Scotty @ AOR
#83
well, time flies when your having fun...No pics of anything important right now. I just placed my order for the rest of the parts I need for the swap. Decided to get everything in 1 spot before I start this thing.
picked up some 5:29's, install kits, and solid pinion spacers (thanks Scott at AOR):
Ordered M/C heavy duty inner axle seals for the front
rear axle service kits
low pro drain plugs
hub orings ect (thanks to Nicholas at marlin for the help)
http://www.marlincrawler.com/
and after work today, I pick up my 35x12.5x15 Maxxis bighorn's
Only thing left is the drive lines which will be done at a local old timer driveline shop
(walker driveline for those local to me)
Pic will get uploaded once we start. could be a bit as the shop I'm working out of may be moving in the next couple of weeks....only time can tell
low pro drain plugs
06-01-2021 01:51 PM
