cheap-ass' 1990 Pickup Build-Up Thread
#81
#82
Ive been trying to find mounts for my chevy axel the only ones i can find are 2 inches shorter than the factory
#85
#87
Does any one know if i can switch the power steering lines that go between frame the frame rails at the bottom of my radiator to soft lines instead of hard?
#88
You could but the hard lines act as coolers for the fluid. On the 4cyls they used a looped piece of hard lin
e but on the v6 the hard lines you speak of take care of that.
#90
Ok so if i make these lines soft lines nothing bad will happen? can i run it through the auto trans cooler part of the radiator?
Here are just some of finishing up the rear.
#92
Old thread here talks about it, post 10 seems to have some good info: https://www.yotatech.com/forums/f123...diator-101806/
#94
If i built another i would start with a 88 3.0 extra cab 2wd and put a 3.4 in it but that's just dreams haha i gotta get this one done first.
#98
I will run anythinng from a 35-39 thats what the plan is but as of right now 33's haha
If anyone was wondering that is a 1996 Tacoma 4wd grille and it fits good with a little work and my front axle is 4" forward with a wheelbase of 126"
#100
There was just a little trimming of some supports off the grille and the black corner things that are under the head lights but i already had my mechanic tell me he wants to put that grille on his truck.
