86bedlesstoy's 1986 4Runner Build-Up Thread
Old 10-26-2011, 07:13 AM
  #41
Z's Confederate Toy's Avatar
I know its not the greatest pic but its the only one I got. Inside the red circle is the plate/cover thing Im talkin about. Check for looseness or missing bolts. Im thinkin that is the cause of your problem.
Old 10-31-2011, 10:16 AM
  #42
86bedlesstoy's Avatar
I'm looking now. can't see ˟˟˟˟! Ha. Lots of coolant back here though!
Old 10-31-2011, 11:18 AM
  #43
Now I'm seeing on a Marlin Crawler forum that the head bolt torque at 62lb. I read in the Chilton manual that it is something different!
Old 10-31-2011, 02:59 PM
  #44
I torque to 60. Anywhere in there is really pretty good. 58 is what the Haynes says to go to but the FSM says 62. I jus met in the middle. You will most likely have to do the head gasket again if it wasnt torqued properly.
Old 11-01-2011, 06:45 PM
  #45
I'm tourqed At 62
Old 11-01-2011, 06:49 PM
  #46
Were you able to check that block off plate on the back of the head?
Old 11-02-2011, 12:53 PM
  #47
Still can't see anything. And now there is 12" fresh on the ground! Ha! Looking a new ARP with complete head and all. Some where around $1,850.. Might be a lot of money to fix this bitch.
Old 11-02-2011, 01:57 PM
  #48
Lemme see if I can take a better pic. It shouldnt be that hard to see.
Old 11-02-2011, 11:48 PM
  #49
Well I have no more compression. Enfinenust cranks.
Old 11-28-2011, 12:17 PM
  #50
Getting engine from Yoda Jim's within the up coming weeks. Jim tells me his go to installer Jesse Myers in Golden is the man for the job. Cost of Engine somewhere around $800-$1,000. Install around $850.
Old 12-01-2011, 12:51 PM
  #51
Jim's out of Denver has a 87' 22re with 108k for $1,000. Doing all new seals oil pan, valve cover, crank and, rear main seal.
Old 12-05-2011, 11:19 AM
  #52
Thursday is almost here! Can't wait to have the engine in and driving!
Old 12-08-2011, 04:27 PM
  #53
Dropped it off and feeling good!
Old 12-13-2011, 02:58 PM
  #54
Back and running. Sad I had to pay somebody to put the engine in but that was my only option. Now I need some 30x9.50 BFG ALL TERRAINS
Old 01-09-2012, 12:18 PM
  #55
Fresh install of a set of Big O A/T's stock size. $590 installed. MMMM Fresh knobys! Time for new shocks as well.. Must pay bills first!
Old 01-22-2012, 11:23 PM
  #56
Still running great. Damn I need a radio! My iPod kind of works if I don't turn the fan on..
Old 01-23-2012, 08:09 AM
  #57
Cant beat that. We ought to put together a wheelin trip. Hows the weather up there in winter land?
Old 01-30-2012, 11:19 AM
  #58
Snow around here. I'm in Breck now. 10" storm on Thursday night..
Old 02-03-2012, 12:03 AM
  #59
I see 4wheelparts has a BUY 4 Pro Comp shocks get a FREE steering stabilizer! Add a Pro Comp Add a leaf and my stock Runner suspenion would be very plush for sure. All for around $160!
Old 02-03-2012, 08:46 AM
  #60
Sounds like a good buy and should make that runner ride alot better.
Quick Reply: 86bedlesstoy's 1986 4Runner Build-Up Thread
