algranger's 1984 Pickup Build-Up Thread
#81
good job im givin you props.
#82
thanks i was pleased and surprised with my work
haha well i was using like an 8" long sawzall blade for wood/metal i was cutting that corner where the bed floor meets the side and the blade punched through and tore the hell outta that. i just pounded it in like half an inch and bought a gallon of bondo
i had the 1/4" gap issue too, i broke the sheilding gas off of my welding rods and welded them in the gap with the mig.
one way i found to improve the gap issue was to tack it together in 4 spots, then run a sawzall blade along the whole cut and it will take out any spot where the metal touches itself, then cut the tack welds and retack it a little closer. keep doing this till its all flush. i just lost paitence and filled it with rods.
#83
im starting the lift right now everyone as soon as i drop the gas tank im gonna cut the rearend off so stay tuned.
this is a 2wd bed too there were different ones some had the outter lip and some, like this one, had the inner. i got the 2wd parts truck for free! all it needed was a timing set and new valves so it was my donor motor, red body parts, interior and seats.
nice! this one had new tires too i paid 700 for this and its base model, rusted out, and had a bad motor so id say 400 is a pretty damn good deal. theres no way im puttin an lc motor in it i just spent 3 paychecks to get a late model 22r in there so i can efi it i have dreamt the lc dream though
#84
#87
starting the chev 63" swap heres before i started cutting it apart
as i lowered the axle i realized i would need to lower the brake line as well so i made a little drop bracket
sheetmetal prototype hangers recive approval
after approval the real deal is created and welded on
how it sits now
how it sits now
#89
oh btw i lost my brakes today so it looks like ive got my next project lined up. theres a little jet stream of brake fluid coming from one of the lines next to the gas tank it shoots about 5' high i must have cracked a line when i was workin on the lift
#91
I would throw something on the front of the hangers to make the transition from the frame rail a little smoother, so you don't end up being caught on them or even worse tweaking one while wheeling.
#92
yeah good idea i'll do that.
got the bed on. turns out 12" was more than i wanted to go (i had to cut the frame too) but overall i'm pleased with the outcome.
we've got some massive flooding here so my yard is a prime playspot. i'm gettin a decent little mud run goin over in the southwest corner
#94
thanks. i'm gonna put mixed rear packs up front and then get some meats on there.
ive decided i do like the 12" bob i cut the frame flush with the hangers and the bed is about that too
#99
