85 SR5 regular cab "street worthy"
Old 06-26-2012, 08:28 PM
NIGHTMARE's Avatar
bad to good news
Well, I'll start with the bad news first as it leads to the good! I pulled the drain plug on the motor and the ''oil'' started to pore out into the pan. As I started getting all of the tools together to finish tearing it down I noticed a heavy gas smell! So I swiped my finger in the oil that was draining to look at it, I bet 80 percent of "oil" was gas! I pulled a little over two gallons out of the motor!!!
So I figure one of the injectors was stuck open and the PO never knew it. As I started tearing it down I noticed everything was really clean on the inside!(thanks gas) He never ran the motor I figure as all of the bearings were fine. Just a little brass showing on a few of them. Finished tearing it down and taking it the machine shop Friday. Didn't take many pics because of the grease and the wife just wouldn't help.
Old 06-30-2012, 12:53 AM
NIGHTMARE's Avatar
Started cleaning a few things up as I'm waiting on the parts to get here on the motor and the next pay check. So I painted the valve cover tonight.
Old 07-13-2012, 07:55 PM
4Nmissile's Avatar
Nice build up. I plan on putting a 22RE in my own 1985 pickup very soon. Are you going to rebuild the entire engine? You'll definitely save some money doing it yourself. Keep us posted.
Old 07-13-2012, 09:00 PM
NIGHTMARE's Avatar
Yes I am building the entire engine. The machine shop said I needed to bore the motor 20 over, so I'm taking his advice. Hope to order the rebuild kit from Tod or Ted soon! I have most parts cleaned up for the rebuild. Ill get picks up soon!
Old 07-19-2012, 09:58 PM
  #25
j.burton50's Avatar
lemme get that bumper man! ill trade you my stocker and some cash pm me bout it
Old 07-20-2012, 06:50 PM
  #26
NIGHTMARE's Avatar
Parts truck
Thanks J!!! I might get back with you on that!
But............
I bought a parts truck yesterday and only going to use a few parts! I will probably put it on the part out section here soon. If anyone needs something just send me a pm. It's an 86 single cab 4x4, had a blown head gasket and was never finished putting it back together.
Some pics
Old 07-20-2012, 09:09 PM
  #27
cabot's Avatar
The white looks good! The SR5 looks like it's in pretty good shape body-wise. I just picked up my first Yota. It's an 85 SR5 as well. I'm going to be running through it and cleaning up all the little problems to ensure that it's a reliable daily driver. Sounds like we're starting similar projects around the same time.
What's up with your steering?
Old 07-20-2012, 10:00 PM
  #28
NIGHTMARE's Avatar
Thanks Cabot, far from where I want it to be! The steering is just wore out! Walks all over the road, and it is need of an upgrade! I saw your truck looks pretty solid. You should put some more pics of it up on your build thread.. Interior and such
Old 07-22-2012, 07:51 AM
  #29
4Nmissile's Avatar
Do you know what condition the diff gears/full differentials front and rear are in? I am looking to get some new or used ones for my 85. I guess I should first ask if you are planning on using them or selling them shouldn't I?
Old 07-22-2012, 11:23 AM
  #30
NIGHTMARE's Avatar
Lol, we can work something out with them! I don't need them
Old 07-22-2012, 01:30 PM
  #31
4Nmissile's Avatar
Let me know about the diffs. I will keep up with your build thread to see how it goes.
Old 07-22-2012, 01:33 PM
  #32
4Nmissile's Avatar
BTW, I like how it looks as if the bars in the back of the donor truck aren't even attached to the truck. The bars look nice, but I don't know if I would need them. That is if you are selling them as well.
Old 07-22-2012, 03:48 PM
  #33
NIGHTMARE's Avatar
So far I'm just keeping the ignition switch, front bumper, radiator, window regulators, and transmission. So, roll bar 50$ sound good? And consider the difs yours 4n. You can PM me if you need anything else
Old 07-22-2012, 09:32 PM
  #34
j.burton50's Avatar
let me get them hub locks i dont like my warns i want the original red rings
Old 07-23-2012, 06:29 AM
  #35
NIGHTMARE's Avatar
No problem J! As soon as I get my truck back on the street I'll start pulling the parts truck apart
Old 07-23-2012, 03:19 PM
  #36
4Nmissile's Avatar
Are you going to use the rubber shift boots from the donor truck? I could use them. Right now you can see through the floor around my shifter to the street !
Old 07-23-2012, 06:27 PM
  #37
NIGHTMARE's Avatar
Not sure just yet on the shift boots, I'll look and see what I have and let you know. I may use the shift boot. I'll let you know soon
Old 07-28-2012, 11:15 AM
  #38
NIGHTMARE's Avatar
Get a good look guys! It's the last time you will see her like this!
I do have an extra shift boot if you want it 4n?
Old 07-28-2012, 11:20 AM
  #39
NIGHTMARE's Avatar
Hey J, if you want the bumper it's yours! I'm not going to use it and it's taking up space now.
Old 07-28-2012, 02:58 PM
  #40
4Nmissile's Avatar
Definitely on that shift boot. Do you have the metal bracket that it all mounts to or no? I could really use it, but either way I need the boot. I just got some pictures taken of my truck which I will post on here. Two show the holes by the shifters where you can see down to the ground.
Quick Reply: 85 SR5 regular cab "street worthy"
