southernZ's 1980 Pickup Build-Up Thread
Old 09-10-2011, 05:19 PM
  #41
Z's Confederate Toy's Avatar
Lookin good man
Old 10-08-2011, 05:59 AM
  #42
southernZ's Avatar
Well time to update. Last night I pulled the front axle and started dissassembly and cleaning. It was crazy all the sand/mud/metal in the housing. It turns out at one point in this trucks life the pinion gear chewed up the carrier and whoever "repaired" it did not get all the metal shavings out. After pulling the axle I found that the pinion bearing was wiped out, so I have to go and get one today. I pressure washed everything inside and out. Then I started the long process of sanding the knuckles, dust covers, and axle housing. Afterwards i sprayed on some rust reformer paint and called it a night. Today ill start re-assembley. Here is some pics:
Old 10-08-2011, 06:06 AM
  #43
southernZ's Avatar
Sorry for the terrible pictures....That camera has been run over (by the toyota)...
After i finish with the front axle im going to finsh up painting the frame, then ill be waiting on parts. I should have a set of 3" front springs that i bought from a member on here headed my way soon, and i ordered some rancho 5000 shocks and steering stabilizer. I will probably go the dropped draglink route on this truck depending on how much of a bind the stock draglink is in after i install the lift. Then after hunting season ill repair the passenger floorboards, and start some body work.
Old 10-09-2011, 10:58 AM
  #44
southernZ's Avatar
Here are some updated pics:
Old 10-09-2011, 11:07 AM
  #45
southernZ's Avatar
All the bearings in the diff need to be replaced. This means i can not fully assemble the axle until it is addressed. I have never set up a differential before, so this will be the first! I took apart the hubs and cleaned up everything in there.
Old 10-09-2011, 04:41 PM
  #46
slacker's Avatar
lookin good
Old 10-09-2011, 06:48 PM
  #47
southernZ's Avatar
Thanks slacker. I plan on giving the rear axle the same treatment....
Old 10-15-2011, 03:24 PM
  #48
southernZ's Avatar
I ordered a master rebuild kit for the front third from Wabfab, and a set of Rancho RS5000 shocks and steerind stabilizer from 4wheel parts. KillerB on here should have some 3" leaf springs headed my way as well. Everything should be in by the time I make it home from offshore. Caint wait to put it all together.
Old 10-20-2011, 04:50 PM
  #49
southernZ's Avatar
I am at a dilemma....... I am trying to decide on what tire size to go with, 31x10.50 or 32x11.50. My truck has the 4.38 gears so im thinking I might be able to get away with some 32's.... also I am planning ob restoring the factory steel wheels but I can not make up my mind to use them or the aluminium wheels I have (pictured above). When I get the front axle back under it I will have some 3" lift springs under it. Any comments/suggestions?
Old 10-20-2011, 05:40 PM
  #50
Fossilized
Staff
dropzone's Avatar
personally I would go with the 31's or flip a coin
Old 10-20-2011, 06:21 PM
  #51
4x4YOTA's Avatar
get some 33x10.50s they fit perfect on stock wheels/truck and can easily be turned by 4.37s
Old 10-22-2011, 02:53 PM
  #52
Staff
Terrys87's Avatar
That rust reformer paint you used turned out really good. You got the brand and where you got it?
I seen a truck the other day with with 33s and looked good and was wondering about gearing.
Old 10-22-2011, 04:47 PM
  #53
southernZ's Avatar
It is the Rustoleum brand rust reformer. I have used it in the past on arc frames and racks and it works fairly well. It dries a flat black color. On my axle after sanding I sprayed 3 coats of the rust reformer and 3 coats of clear. It came out pretty good I think. I got mine from Home Depot.
Old 10-22-2011, 04:52 PM
  #54
southernZ's Avatar
Im just a little hesitant w/ 33's and this 20R....I would love to use the stockers but they are so dang heavy.... Decisions decisions...
Old 10-22-2011, 04:54 PM
  #55
southernZ's Avatar
Originally Posted by southernZ
It is the Rustoleum brand rust reformer. I have used it in the past on atv frames and racks and it works fairly well. It dries a flat black color. On my axle after sanding I sprayed 3 coats of the rust reformer and 3 coats of clear. It came out pretty good I think. I got mine from Home Depot.
It retails about $10 a can
Old 10-25-2011, 12:45 AM
  #56
Staff
Terrys87's Avatar
I will be checking them out soon. I will be glad to get mine to the point where you are. Just to drive it would be a nice accomplishment.
Old 10-25-2011, 04:51 PM
  #57
4x4YOTA's Avatar
i had an old work truck/plow truck that had a 20R stock 4.37 3rds and ran 35s... just dont plan on winning any races...
Old 10-26-2011, 09:49 AM
  #58
southernZ's Avatar
Hmmm....I might try 33's......who knows
Old 10-27-2011, 09:52 AM
  #59
southernZ's Avatar
Hopefully the parts for the front 3rd will come in today so I can rebuild it and get the axle back together....
Old 10-27-2011, 10:08 AM
  #60
waskillywabbit's Avatar
Let me know if you need something else.
:wabbit2:
Quick Reply: southernZ's 1980 Pickup Build-Up Thread
