Vehicles - Parting Out Parting out a vehicle, post it here
FS[NorAtl]: 1986 Toyota Pickup 4x4 Extended Cab
Old 09-25-2015, 07:36 AM
muddpigg's Avatar
Thanks for trip journal. Didn't know about liberator crash. Would like to check that out.
Old 09-29-2015, 03:29 AM
mct75's Avatar
How much for all the AC components?
Old 10-18-2015, 01:04 PM
toyospearo's Avatar
you still have the body to this truck
I am looking to do a cab swap. Yours looks pretty good and if you have it I need it. Not sure where you are??
Old 11-04-2015, 04:26 AM
Tony_Ubar's Avatar
Does the exhaust manifold have a o2 sensor port in it? If so how much? 97002
Thanks!
Old 11-18-2015, 04:12 AM
  #25
Tj02tacoma's Avatar
Steering column cover.
Do u still have truck? And if so would like to see what u have left!
Old 12-23-2015, 10:09 AM
  #26
BlackStone's Avatar
How much for the heater control pigtail w/ 10" of wire behind it? mine melted recently. I think I see it hanging there in the picture with the shifter. Also the metal shifter palte with rubber boots. If the transmission is a G52. I'll take the shifter too.
The plug That hooks into the heater fan switch(low-High) circled in Yellow.
The shifter metal bezel in Red. And if it is a G52 trans, I'll take the shifter. Thank you!
Old 12-23-2015, 10:13 AM
  #27
77lubr's Avatar
Sorry guys, but I pulled the drivetrain and scrapped the truck. I'm going to swap it into a rust free 1987 Mitsubishi Montero I nabbed for $700 with a bad motor. The harness needs to stay with the motor as well as the shifter and boot.
Old 01-15-2016, 07:32 PM
  #28
silverdilly's Avatar
I need to know if you have the load sensing proportioning valve and I need one asap! please help me find one!
Old 03-17-2016, 02:19 PM
  #29
Pops87's Avatar
Hello there
I'm not sure what it's called , but I'm in need of the black louvered trim piece that is right behind the door. I'm in need of the driver side. Do you have one on you truck? If you do, how much would you want for it?
Thanks, Darrin
Old 04-18-2016, 12:08 PM
  #30
OlGrunt's Avatar
I am looking for a complete w-56, Bell back with driveshafts, flywheel and clutch. Give me a price. I have a buddy going to Pa shortly. Thanks
Old 06-17-2016, 05:55 PM
  #31
4runnerCal's Avatar
Still have the front axle?
Weidle
01-21-2019 05:39 AM
Valvoman
06-28-2015 02:45 PM
bprice0077
06-25-2015 07:36 AM
dirtrider0129
10
06-24-2015 12:24 PM
wagigknp
06-24-2015 12:02 PM
Quick Reply: FS[NorAtl]: 1986 Toyota Pickup 4x4 Extended Cab
