FS[NorAtl]: 1986 Toyota Pickup 4x4 Extended Cab
#26
How much for the heater control pigtail w/ 10" of wire behind it? mine melted recently. I think I see it hanging there in the picture with the shifter. Also the metal shifter palte with rubber boots. If the transmission is a G52. I'll take the shifter too.
The plug That hooks into the heater fan switch(low-High) circled in Yellow.
The shifter metal bezel in Red. And if it is a G52 trans, I'll take the shifter. Thank you!
#29
Hello there
I'm not sure what it's called , but I'm in need of the black louvered trim piece that is right behind the door. I'm in need of the driver side. Do you have one on you truck? If you do, how much would you want for it?
Thanks, Darrin
Thanks, Darrin
dirtrider0129
10
06-24-2015 12:24 PM
