85 4Runner *$900* pics
85 4Runner *$800* pics
1985 Toyota 4Runner
22RE
top shift case
trans and tcase both great
solid front axle
fuel injection
power steering
tilt steering column
rocks sliders
rear cage
new water pump, new timing chain with metail guides, new oil pump, new fuel filter, every fluid in the whole truck replaced, brand new clutch w/resurfaced flywheel, new and complete tune up, new battery w/ warranty, and more.
Removable hardtop in good shape. Rear power window works!
Has 199k on body, 14Xk on motor. Neutral safety switch bypassed, starts in gear no problem. Has factory cassett player.
Body has some rust and dents, but frame has NO holes!
This truck will start and drive, but needs some work. The motor needs some fine tuning after receiving a block swap (vacuum stuff may be off and TPS shows an error), but motor has good compression (170,175,160,170 iirc).
Sale comes with a spare rear axle with 4.10 3rd member, full set of 2.5" lift springs, and even 2/3 bald 33's. Also have a spare EFI head, spare radiator, spare steering, spare master clyinder, and all necessary parts to do IFS hubs and brakes on front axle. I probably have more parts than that. This truck also comes with a rear hitch, tow hook, a chiltons manual, AND a factory service manual on CD in PDF format.
Located in Detroit.
PRICE: 900
contact me over email: davekerwin AT gmail.com
Originally Posted by madbronco
take any trades??
but I really want the cash, because I got no where to put a project truck right now, I live in a condo now, and association rules are a real bummer.
Originally Posted by FrazDaz
How's the frame on it? Mines an 86 and it's cancer is pretty bad. Salt must be pretty rough on 'em up there in Mich-a-gain too
Originally Posted by SlightlyModified
I may be interested if it doesn't bother you that it will be cut up for an f-toy project???
Originally Posted by AznSky
Hi Dave!
My buddy from work is going to check out the truck this weekend. I belive you talked to him already
I am waiting on his call to set up a time.
First with cash gets the truck, price is now $800
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
