3rd gen 4runner roof rack/parts
I am looking for a part for my 4runner, i need the little parts at the end of the roof rack rails. They should be few inches long to make the rack rails flow into the body, i need all 4 of them. I also may need the rails.
Thanks
Thanks
im in need of the L thumb wheel hardware, 8pcs total, if anyone has some.
https://www.yotatech.com/attachments...tock-parts.jpg
If you guys go to the junk yard and look not only at the Toyota's but over at the domestic mini vans you will see that a lot of the rack parts have the same look to them.
I got all my parts off of a couple different mini vans, one was a pontiac and the other was a Chrysler. I just shortened the longer items down.
End caps and set screws knobs are probably going to be pretty close to the same. I couldnt tell the difference when i finished and compared to stock Toyota.
Wow old thread
Just get some washers and a bolt and wing nut. Thats what i am using now.
Yeah i found my stuff at a junkyard, just none of the end caps i got worked, so i ordered some from toyota. Wasn't bad at all. I paid around 40 bucks for a roofrack.
thats what im trying to do...
didnt think i could squeeze a bolt under the sliding plate(for the stock rails) like that.
guess ill try it this weekend. thanx.
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
