2001 4Runner 4x4
Old 08-01-2015, 11:30 AM
mussy01's Avatar
2001 4Runner 4x4
Finishing out the part-out of a 2001 4Runner SR5 4x4 AT with 78,000 miles that I purchased as a running donor for a 3.4L swap. The parts listed below are all that I have left. All prices listed are negotiable and I'm ready to make a deal on bulk buys. All prices listed are pre-shipping, which will be paid for by the buyer. All parts will be shipped from zip code 80526. I have pictures for every part on the list so please let me know if you'd like me to post or IM something specific. I will update the part list once an item is sold.
- Front driver and passenger quarter vent windows - $50/both
- Air bag sensor assembly (89170-35120) - $40
- Steering wheel air bag assembly - $50
- Engine Control Unit 4x4 AT (89666-35420) - $100
- Passenger side dash air bag - $50
- Radio Amplifier (86280-35080) - $25
- Gas filler door & cap - $15
- Dash gauge cluster trim (black) - $15
- Washer fluid pump (85330-35070) - $15
- Buzzer (89747-35010) - $10
- Antennae Relay (85914-35010) - $10
- Yaw Rate Sensor assembly (89180-35010) - $40
- Running light relay assembly (82810-04011) - $20
- Tailgate power window motor (85710-35110) - $30
- Horns (2) - $10/both
- Rear wiper motor assembly (85130-35070) - $30
- Single door lock switches (2) - $15/ea
- Hood hinges (2) - $10
- Front windshield wiper frames (2) - $10
- A/C compressor - $50
- Throttle body - $50
- Driver front window regulator motor - $30
- Driver side exterior door handles (front & rear - forrest green) - $15 both
- Front door speaker assembly (1) - $10
- OEM MAF sensor (22204-21010) - $40
- Assorted relays (90987-02012 six; 82642-35010 one; 85926-30020 one; 90987-02006 one) - $25 all
- Dash board filler plugs tan (1 large, 3 small) - $20 all
- Flasher - $10
- Traction control switch - $10
- Hazard light switch - $10
- Heater assembly (87110-35040) - $75
- AC cooling unit (448800-4620) - $75
- 4wd control computer (89533-35170) - $40
- Harness assy, towing converter (08940-35810) - $30
- Box of body harness pigtail connections (nearly complete) - $75
- Engine wiring harness (missing one ECU connector from swap) - $125
- AC condensor - $30
- Front driver side door glass - $30
- Rear driver side door glass - $30
- Sunroof glass - $50
- Front Passenger door (complete - forrest green) - $60
- Front & rear driveshafts - $60/both
- Fuel tank with pump (complete) - $60
Thanks for looking!!
mussy01 is offline
Old 08-13-2015, 10:51 AM
todos4runner's Avatar
Do you have pictures of the steering wheel?
todos4runner is offline
Old 08-13-2015, 06:41 PM
mussy01's Avatar
I do not have the steering wheel but I do have the airbag with the steering wheel pad/cover intact, if you're interested in that. Just let me know. Thx
mussy01 is offline
Old 08-13-2015, 06:55 PM
881stGenRunner's Avatar
in dash clock?
881stGenRunner is offline
Old 08-13-2015, 06:57 PM
also does the truck have the factory fog lights and headlight/fog light/turn signal stalk?
Old 08-18-2015, 05:09 PM
mussy01's Avatar
Unfortunately i don't have either of those items left. Thx
mussy01 is offline
Old 09-01-2015, 10:39 PM
tinigunner11's Avatar
Well not sure on the technical name for the part I'm looking for, but there's a little rectangler body filler under the head light. I'm missing the one on the drivers side or my 4Runner. Any chance you have that and are willing to part? I can post a picture also if needed.
tinigunner11 is offline
Old 09-07-2015, 03:00 AM
sashcraft's Avatar
Front skids? Also, pic of the gas filler door. Thanks.
sashcraft is offline
Old 09-19-2015, 12:50 PM
mussy01's Avatar
Sorry for the late reply but I do not have this part. Thanks!
mussy01 is offline
Old 09-19-2015, 12:54 PM
mussy01's Avatar
I do not have the front skids but I've attached a couple pics of the fuel filler door. It is hunter green in color. There are no dents but you can see fine scratches in the pics.
mussy01 is offline
Old 09-20-2015, 09:32 AM
Jarhead74's Avatar
Hey,
Looking, not sure if I missed it from your list, but here is what I am looking for:
center dash vents
Sunroof assembly-specifically the copper tubes/wires that pull the window-If it worked. Mine are frozen
Intake hose-goes from airbox to intake.
Shipping would be to 29860.
Thanks.
Jarhead74 is offline
Old 09-26-2015, 03:22 PM
Citykid's Avatar
You don't have the rear end do you? The whole differential and axels.
Citykid is offline
Old 12-13-2016, 02:50 PM
zmbombr's Avatar
Are you still parting this out? Could you provide an updated list of anything available?
zmbombr is offline
Old 12-13-2016, 08:20 PM
Fossilized
Staff
dropzone's Avatar
Thread now closed, OPPO hasn't been around for 6 monthx
dropzone is offline
MO transplant
04-23-2023 11:58 AM
Colington
03-08-2020 09:51 AM
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 2001 4Runner 4x4
