1990 toyota pickup
1990 toyota pickup
i am selling my 1990 toyota pickup. it has a brand new 3.0 v6 (10,000 miles), 4x4, manual transmission, custome flatbed, and tons of new parts. some new parts include brand new leaf springs ($800), clutch, timing belt, starter, battery, alternator, carrier bearing, rear u-joint, rear brakes, sway bar links, passenger side wiper arm, 31" bfg all terrains on american racing outlaw II wheels (tires are about 50% maybe a touch less, rims are in good shape), i have a full size matching spare that is just about 100%, i also have brand new backing plates for the rear wheels that havent been put on yet. it 2 new fenders, new grille, bumper, valance, and the hood has been repainted. the cab corners, rockers, and doors will need replacing. also, the truck has trouble getting into gear. the clutch mount on the firewall has cracked before and left me stranded over an hour away from my house. i believe this is the same problem because at the time i was in the process of getting a new car so i just welded the mount back. i think it is just getting flimsy again. before that issue, the tranny shifted mint so im positive it is just the clutch mount that maybe be starting to crack again. it currently needs a water pump. i will most likely do it myself, but if not, i checked out prices and i found one for under $50.
i know im missing some things but this gives you an idea of what it is.
i am located in Leominster, Massachusetts. you can pm me with additional questions or call if you want...978 833 7513.
I may also part the truck out.
Thanks for looking!
Thanks for looking!
6th Gear
19
12-10-2019 07:31 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
