tire size question...
Old 12-10-2008, 04:31 PM
Ned
Ned's Avatar
OK, I see the tire conversion chart, but I don't get it. How a 265/75R16 = just shy of a 32" tire and so does a 235/85R16.
If I'm reading the chart right, the stock 265/70R16's on my Runner = about a 30.5x8R16??
So if I'm looking to get about a 32" tire, which one would be better?
Old 12-10-2008, 05:33 PM
stoicheg2's Avatar
265/75/16 would be considered a 32" tire from what i understand
Old 12-10-2008, 05:47 PM
sexonwheels's Avatar
It all has to do with the series of tire. If its a 265/75 then it will be pretty tall, if its a 265/35 then it's going to be small. And I believe 285/70's are equal to a 32. Doesn't matter which one you get there both the same, its just one is advertised as metric and one is advertised as imperial.
Old 12-10-2008, 06:02 PM
Windsor's Avatar
For the OP, it helps to understand the numbers.
First number is tread width (roughly) in millimeters
Second number is sidewall height expressed as % of first number
Third number is rim diameter (measured at bead)
Old 12-10-2008, 06:45 PM
Ned
Ned's Avatar
aahhh, I think I'm getting it..
Thanks !
djpg2000
11-11-2020 04:56 AM
jgallo1
10-26-2015 06:39 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
Luvmeye22re
08-04-2015 03:53 PM
coffey50
07-28-2015 10:55 AM
Quick Reply: tire size question...
