Fitment help.
Old 04-28-2009, 09:27 PM
turboboost's Avatar
Fitment help.
Hey guys, I'm just curious if the stock aluminum rims found on Second Gen 4Runner will fit a 1985 Solid axle pickup? I seem to recall reading something regarding the backspacing on the aluminum ones, but (of course) can't remember if it fits or not.
Anywho, I did a quick search, but my search terms were WAY too broad to find an answer even remotely close.
Also, if they DO NOT fit, are there any 15" wheels that would fit found on any other brands of trucks that could be had easily at a wrecker? (Think GM, Dodge, Nissan, etc.) Since there isn't a single solid axle Toyota around here I was hoping I could do some cross-breeding just to get my 28" tires mounted to roll around on my 85.
Thanks in advance!
Old 04-28-2009, 09:29 PM
scuba's Avatar
I cant pony up a for real yes, But most toyota trucks use the 6 on 5.5 bolt pattern
They should work, If your not sure test fit before you purchase..
Old 04-28-2009, 09:31 PM
turboboost's Avatar
I know that the bolt pattern is the same for sure, but I seem to recall reading something to do with the tie-rod contacting the wheel, due to the funky back-spacing. I could just be mixing up my memory though, that happens all too often for me. Thanks though scuba, much appreciated.
Old 04-28-2009, 09:43 PM
turboboost's Avatar
Well I seem to have found my first answer; no they do not fit on the front axle. Damn.
Now I'm on a quest for junkyard wheels. Anybody have any idea?
Old 04-28-2009, 10:12 PM
scuba's Avatar
Did you do a test fit..?
What doesnt fit about them..Just curious..?
Old 05-01-2009, 03:12 PM
turboboost's Avatar
Yes, I tested them. The offset seems really funky, the inner wheel touches the tie rod of the solid axle.
Old 05-01-2009, 03:49 PM
4Crawler's Avatar
Yep, solid axle factory wheels are approx. 3-3/8" backspacing:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/22.html
while the IFS wheels are around 4-3/4":
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
And much more that 3-3/4" back spacing on a solid axle and the wheel (15") will hit the steering components. Wheel spacers would be an option if you wanted to run those wheels.
Old 05-01-2009, 10:39 PM
kcpanages's Avatar
they wont fit. u will need wheel spacers. i had a 03 taco and tried to run the taco rims on my 84 and the tie rods ate the rims up bad. had to put spacers on......... all yota pickups,taco's and 4-runners are same lug
Old 10-14-2009, 01:15 PM
curlyeliot's Avatar
I am brand new to the site and also have an 1985 4runner and am also looking for some used wheels. I was wondering if there would be a problem with running 16" tacoma wheels on my 4runner because there is a lot more of those available in my area. Or would it be better to just get spacers? Thanks.
Old 10-14-2009, 01:17 PM
4Crawler's Avatar
Backspacing issues would require spacers:
'85:
'86 and later:
Old 10-14-2009, 08:08 PM
curlyeliot's Avatar
Thanks for your help. After your post, I went out and pulled a wheel from my wifes 06 tacoma and tried in on my 4runner. I'm a little slow but now it makes sense. Thanks again.
Where is the best place to order 1" spacers?
Old 10-15-2009, 01:55 AM
turboboost's Avatar
Wabfab, he has a deal right now for free shipping too, just use the promo code "YJMudder."
kawazx636
10-06-2021 03:03 PM
zytra
01-24-2019 03:16 PM
Shagool22
09-28-2015 07:53 PM
fountain
09-28-2015 03:04 AM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: Fitment help.
