31x10.50 15s on a 6 or 7 or 8inch rim?
Old 09-22-2014, 03:44 PM
travisamorgan's Avatar
i got a 94 3.4 swapped 5 speed extended cab pickup and plan to get new tires for it. it currently has on 235/75r15s and i am planning on running 31x10.50 15s. i have the stock 15x6 rims.
will 31x10.50 tires fit and run safely down the interstate and do slight offroading safely on a 6 inch wide rim? or would it be better on a 7 or 8 inch wide rim? i do air them down a bit when i offroad.
thanx travis.
Old 09-22-2014, 04:15 PM
Fossilized
Staff
dropzone's Avatar
They will kind of donut on a 6" rim, some tire shops probably won't mount them on that narrow of a rim
15x7 would be better, 15x8 even better
Old 09-22-2014, 04:55 PM
Teuf's Avatar
I say 15/8 also. that will accommodate many size tires.
Old 09-22-2014, 04:59 PM
oldblue's Avatar
[IMG][/IMG]
i ran on my stock 15x6 for a while before i got my 15x7 with no problems at all. i really want some 15x8 with an offset to make the tires look a little wider and keep from rubbing the upper control arm at full drop.
Old 09-23-2014, 08:18 AM
Ok will an 15x 8 inch wide rim work without rubbing anything at full turn and full droop and compression?
Old 09-23-2014, 08:22 AM
JasonYota's Avatar
That will depend on the backspacing of the rim
Old 09-23-2014, 11:57 AM
True but what if I get the same backspacing and offset? I thoight I read somewhere stock was 3.75 inch backspacing? I will look when I pull the wheels off the truck next time.
Old 09-24-2014, 02:56 PM
Ivw done some reading and see that most people use 3.75 backspacing. But what about offset? I want a wider looking stance without tearing out my balljoints and bearings.
3.75inch backspacing and what offset?
I dobt know what offset is stock. I read -20mm but unsure.
1uzRunner
63
11-10-2018 03:58 PM
87SR5justin
09-29-2015 02:45 PM
Cycles
09-29-2015 06:37 AM
Bill McBride
09-20-2015 02:51 PM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: 31x10.50 15s on a 6 or 7 or 8inch rim?
