YotaTech Forums
Go Back   YotaTech Forums > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Staging Area For Tech Article Submissions
Sign in using an external account
Register Forgot Password?
Search
Staging Area For Tech Article Submissions Got a tech article to submit? Post it here
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 02-06-2013, 11:16 PM   #1 (permalink)
Personal Sales Rating: (0)
LITLRED's Avatar
Installing a Tachometer in a 86 4Runner DLX
Step 1. Modify the tach to be compatible with Toyota's dimmer circuitry.
Click the image to open in full size.
The Tach came with a +12v illumination lead and one ground wire.
It is modified by cutting the ground side of the bulb and connecting a ground lead to it. I chose to use solder and heat shrink tubing.
Step 2. Attach the wires temporarily to make sure it works before cutting up your dash!
On my '86 the tach signal is a black wire that comes off the igniter. Instead of cutting the wire here, I tapped into it with a voltage tester. I was hoping to find a more convenient tach signal wire at the instrument cluster.
One of the test connectors had a switched +12v connection.
Then connect the ground to a good chassis ground and when the truck starts up the tach should register rpms.
Step 3: Mounting the Tach.
I chose to mount it on the left side of the cluster. Pretty easy.
Step 4: Connecting the 5 Wires
I found a +12v switched power wire and a Tach signal wire connected to the instrument cluster.
Black Tach Signal Wire
+12v switched power wire connection
The 2 illumination leads I connected in parallel with connections previously made for an oil pressure gauge.
The white Tach illumination lead connects to the green defogger switch wire.
The illumination ground connects to the Red/Black dimmer switch wire.
For the main ground i used a ground behind the lower left cover next to the main fuse panel.
The wires fit neatly in the crack between the dash and A pillar without having to drill a hole.
Final product.
__________________
86 4Runner rebuilt 22RE Auto engnbldr kit 0.020 over, denso iridium 5305s, 10.5 x 31 dueler A/T, smitttybuilt front, custom back, RP 10w30, mech oil pressure gauge, alarm, big 3 upgrade, third brake light mod, Galant power antenna swap, starter relay mod, planet audio/pioneer 6 x 9s, Zuk rear spring mod 14 x 125 lb. Tranny Cooler, Equus Tach
LITLRED is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Yotatech
4WD Truck
Paid Advertisement
Tags
4runner, 84, 86, custom, dashboard, gauge, installation, location, oil, pressure, signal, tach, tachometer, tachwire, wire, wired, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
