| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
5.0L 302 Swap, rear axle upgrade
#2 (permalink) |
Ok, I have a 5.0L 302 that will put out about 325hp and 365 ft-lbs of torque, This is going In a 1980 truck. Rear axle upgrade? For Sure…..Chromoly axles or maybe a Ford rear end? Has anyone done this type of V8 swap and modified anything from the transfer case back?
#3 (permalink) |
Get some 60s
cant go wrong there. I wouldnt run a yota axle
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more |
#4 (permalink) |
Or a ford 9" very strong. your toyota tranny and cases will be your next weak link
__________________
#5 (permalink) |
I was thinking ford 9" or "maybe" chromoly axles. I read that some have good luck with them with a 351w. I guess it all comes down to what you do with the truck and how you drive it....
#6 (permalink) |
Ide go with the 9 over just some chromoly alxes. The yota ring and pinion would be what I would be afraid of breaking. be hard pressed to break the 9 and you could put some nice axles in there too. the 9" third is a much stonger design over the yotas
__________________
#7 (permalink) |
Yeah your right, I'll have to start looking around my area for one. As for tranny and t-case, I'm using a Marlin built R150. This is no rock crawler or hard core off-roader. Just a toy with a little attitude....
#8 (permalink) |
I hear ya... Just take it easy on them and youll be golden. I know alot of people with them that absolutly love the power. Its a great motor. Good luck and have fun with it
__________________
#9 (permalink) |
question is how would the over all width compair to the stock yota, from brake drum to brake drum? Would it be a little shorter or longer? I see for a rear end from a early 65-66 housing is about 52"....and what about the spring perch location compaired to the toyota? I guess my question is a Ford 9 from what model would work best?
#10 (permalink) |
im not sure on widths but a good place to find that info would be on pirate. Maybe someone on here could tell you. You can also cut them down or lenghten an axle. Just have to have some pretty good skills or a place to do it and youd have to have custom axles made. but this way you get exactly what you want
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more Last edited by fillsrunner4; 08-06-2009 at 11:36 AM. |
#11 (permalink) |
Cant go wrong with a 14b. Cheap and STRONG. Full floater would be the ultimate.
If I ever upgrade my rear axle, I will for sure go with a full floater.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#12 (permalink) | |
Quote:
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift |
#13 (permalink) |
Banned 'cause I was 4runnerchevy also banned
Put in a ford 9". Hot rodders have been pumping 500+ into them for years. What tranny and case are you using ?
#14 (permalink) |
its a 351 cleveland, right? x (insert number of times here) on the ford 9".
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#15 (permalink) |
The ford 8.8 in the current Stangs is pretty stout too even with the stock splines, I did 4500 rpm clutch drops on 4:10's and they held on my 420 rwhp Stang...
8.8 with some 31 splines and welded tubes is near bulletproof, but the 9inch is cheaper and stronger IMO, just giving you options because the width is so cose on the 8.8's in Exploders, Rangers, and mustangs...
__________________
04 4Runner - Sold 97 T100 - Sold 86 Runner - Project - Sold 02 Mustang GT Vert - Stuff done, 181 GPS confirmed miles per hour on Autobahn A-5 between Stuttgart and Hockenhiem:) For Sale 92 4Runner 3.slow - little lift, ISR, Dynomax catback, manual hubs conversion, Downey rear springs, more coming count on it... |
#16 (permalink) | |
Quote:
i put over 500 thru the 9" in the truck in my sig.. i actually broke a few teeth on the ring gear AND two of the spider gears back in highschool... guess 5,000 rpm clutch drops on 28inch slicks takes its toll lol. i since built it up a tad.. still has the stock 31 spline axles, just a powertrax lunchbox locker (which i hate) and some 4.10 richmonds. ive beat the ever lovin out of that rear and not so much as a noise from it.. the truck weighs like 4800 lbs on top of all the power and abuse.. as far as 8.8s.. are the explorers center pumpkin locations? i know the rangers are all offset, and seems like the ranger is the same playform as an exploder (reference intended, ours caught fire christmas day while we were driving to familys house, steering column just started smoking) -- my point. would you have to rob one from a stang and just stitch on some spring perches?
__________________
1975 Ford F-100.. 416 c.i. 390 based FE stroker, all aluminum top end, tremec 5spd.. 5000lb truck runs low13s spinnin well into 3rd with 2.3 60 fts lol. FUN! 2003 Z06 black/black - daily beater 1988 4Runner 5" superlift, 3" bodyon only 35's... in progress - back from the (long) dead Last edited by coreyc619; 09-30-2009 at 08:49 PM. |
| Tags |
| 302, axle, bone, chromoly, end, f150, ranger, rear, shorter, swap, t100, toyota |
