4l60e swap
4l60e swap
Hi,
I am biulding a 85 toyota with a 4.3 V6 and 4l60e tranny. the donor truck was 2wd. I have the toyota transfer case on the back of the 4l60e.
My question is: how will the PCM control the tranny shifting when I am in low range? will it work good? or will I need to put 4wd programming into the PCM. If I have to put 4wd programming in, what else as far as wiring wil I need to hook up?
