Domestic Swaps Chevrolet, Ford, ect
4.3 Swap questions
Old 10-29-2012, 10:37 PM
UVRUGBY's Avatar
4.3 Swap questions
Alright been searching for 2 days, have read about 15+ threads and not much info on the few questions I have, or the answer was very vague.
The 4.3 SFI is a '96 s10 manual vin code X, will be going into '90 PU ifs with the yota tranny (r150). I know I will need either a custom oil pan, or a diff drop or body lift. most likely going to go with a low profile oil pan.
I will be using the AA bell housing kit.
1) will I be able to maintain the stock clutch/fly wheel from the 4.3?
2) If not, what clutch/fly wheel will be needed?
3) I think there is a vss in the '96, if so what has been done to over come this?
4) who is still making harnesses for this swap?
More questions might come later because I am having a brain blank out.
Thank you
RJ
Old 10-30-2012, 08:26 PM
UVRUGBY's Avatar
anybody?
Old 10-30-2012, 09:51 PM
westjohns yota's Avatar
if im right your supposed to use the 4.3 flywheel, clutch and all that, vss? ive never heard of that,
Old 10-31-2012, 01:04 AM
UVRUGBY's Avatar
Perfect. and the VSS- Vehicle Speed Sensor.
from what I have found it sounds like I wouldn't have to worry because the toyota's is in the tranny so I should be ok with that part. I would presume.
Old 01-22-2013, 03:44 PM
90chevota's Avatar
pThe 4.3 SFI is a '96 s10 manual vin code X, will be going into '90 PU ifs with the yota tranny (r150). I know I will need either a custom oil pan, or a diff drop or body lift. most likely going to go with a low profile oil pan.
Thank you
RJ
Howell engine development is where I got mine $350 without computer $500 with computer. I have a stock flywheel with AA bellhousing and clutch. I'm doing the same build. Put a 03 4.3 in my 90 extra cab 3.slow the harness is real simple and labeled for everything. The truck does need a body lift for hood to close and without a suspension lift I could see there being big problems with oil pan clearance. But I too have questions I'm about to hook power steering up and how important is the proportioner thing on passenger side frame rail? Never had one on any of my 4 bangers.
Old 01-22-2013, 04:19 PM
fillsrunner4's Avatar
You use the flywheel and pressure plate from the 4.3 350 or even a 454 work. 11" 163 or 168 tooth I forget the count. And a custom clutch disk to fit the toyota splines. AA sells the disk.
Howell or painless for a harness. And you must use a VSS to make the engine run properly. Some say this is a hoax and some will say its a must. In order to use it however you cannot run a toyota transfer case they are not set up that way but can be converted.
heres a site that has a ton of info on the VSS aspect.
http://www.jagsthatrun.com/
Check out Painless.com for the harness
AA for adapters and clutch stuff
Pirate4x4 has an entire section on the swap also
http://www.pirate4x4.com/forum/toyot...aq-v2-0-a.html
Old 01-26-2013, 09:30 AM
james92toy's Avatar
The proportioner thing on passenger side is for the rear anti lock brakes.
The power steering pomp is what powers it. I took all that out on mine, connected the brake lines together. For the power steering i used the gm lines. Cut the flared ends off the steering box end , take the flared nuts off . Put the toyota flare nuts on that go to the steering box . Buy a good brake line flare kit , it must do double flare and go from 1/8 lines to 3/8 (the cheep ones suck , dont get a cheep one) "Double flare" the pump lines just like brake lines and screw them into the box. Mine work great just like stock lines.
coleypull15
11-03-2015 07:41 AM
keithporter83
07-24-2015 07:37 AM
KBar
07-13-2015 06:01 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 4.3 Swap questions
