Diesel Swaps Diesel engines
90 V6 OM617 4Runner Swap build
Old 04-20-2015, 12:33 AM
Vr4junkie's Avatar
Hey whats going on every one thought i'd join the forum see if I can get some help from some of you guys that have done this swap already.But anyways heres what im working with a 1990 Toyota 4Runner V6 5sd 4x4 and a 1983 300SD engine i took out a running car im using 4x4 Labs adapter plate so far I have both engines out the one part i'm stuck on is fabing up the motor mounts I would like to see some pics of what you guys have done that would really help me out. I will upload some pics as soon as i could figure out how to resize my pics since it wont let me upload .
Old 04-20-2015, 06:52 AM
usmma2013's Avatar
For my build the motor mounts seemed like they would be difficult till I just went ahead and did em.
I re-used the stock Toyota rubber mounts. I bolted the motor and trans together and mocked the Engine/Trans assembly in place as far as driveline angles and motor clearance, allowing for 1/2" or so of sag when the weight was dropped onto the mounts. First bolted plate to the block on each side, then just went to town with cardboard, cut pieces to size, tacked welded the pieces in place, removed the mounts and finished the welds. Not at home now, I can take a few pictures next week.
Old 04-20-2015, 03:22 PM
Vr4junkie's Avatar
I would love to see some pics whenever you get a chance.
Old 04-22-2015, 05:24 AM
usmma2013's Avatar
For sure man, I'll take some when I get home.
For the mounts there are many ways to make them up, I found easiest to re-use as much of the toy setup as I could. The important thing is when you design the mounts make sure they are stiff in the forward/backward direction as well, that's an axis most people don't think about but braking/accelerating puts a good amount of force in that plane as well.
Also, I can't see the front of the motor in your pics, but if you remove the PS pump, Vacuum Pump, and Water pump Pulley it will make your life alot easier installing the motor without needing to hack apart the core support.
Do you have a SAS or plan on modifying the oil pan?
Old 04-22-2015, 01:56 PM
Vr4junkie's Avatar
yes I do plan on modifying the oil pan I know I don't have or plan to have a SAS anytime soon but I did take most of the front off but it's still a tight fit.
So I took it out of my brothers shop so I will be working on it as much as possible I'll keep updating my progress
Old 05-02-2015, 02:36 PM
Vr4junkie's Avatar
OK so here's an issue I'm having I put the motor in for a test fit and seems like it might be a really tight fit does the tranny need to be pushed back to make this work.
Old 06-16-2015, 04:01 PM
Vr4junkie's Avatar
Haven't updated any progress lately cause of work and this heat but here's a little update.
New 35x12.50x15 Goodyear MT/R
So Instead of pushing the tranny back and cutting up the oil pan I just extended the front frame
Old 07-16-2015, 04:07 PM
Vr4junkie's Avatar
Some new suspension part's
So here are the motor mounts I ended up fabbing up.
Old 08-01-2015, 03:33 PM
Vr4junkie's Avatar
So these are the motor mounts I ended up fabbing still needs minor adjustments here and there but they fit nice.
Old 08-14-2015, 03:00 PM
Vr4junkie's Avatar
Flywheel finally bolted up
New clutch and slave cylinder
The way the engine sits now there was no need to modify the oil pan or oil pick. Only down side to this is hood can't be closed but that's not an issue for me since this is a play truck but there's alot more room to work on it and do basic maintenance
So oil pump doesn't need to get cut up just need to push stabalizer shock mount more down.
Old 11-12-2015, 03:25 PM
Vr4junkie's Avatar
So the time has come and shes finally running here's a little video of the first start up .. The duck tape is just temporary and the plastic dip will eventually come off too
But here it is
Old 03-14-2016, 11:13 PM
Vr4junkie's Avatar
So here she is AKA FRANKENSTEIN I'm sure you guys know how it got its name. But on the good shes up and running and playing around in the mud installed new LED light, smity built winch, Moroso Wheel studs all around, and my favorite the Aussie rear locker huge difference.
Old 03-17-2016, 08:12 PM
pyrojoe22's Avatar
If you have any problems with your motor mounts, it's probably going to be where the square tube mounts to the rubber isolator. You are creating a huge moment on the head of that bolt. Hopefully it works well for you though. It looks like you are pretty much dedicated to the setup you have since you hacked off your stock mounts. This swap is very possible to keep your grill in the stock location and keep your hood shut. My motor mounts set the motor down so the hood can clear without a body lift. If you change your mind down the road and want to redo it, hit me up and I can help you out.
Old 03-21-2016, 12:19 AM
Vr4junkie's Avatar
What do you mean about the motor mount like add some support or what??
Ill definitely hit you up I remember I would look thru your build thread and few other just thinking one day. But this my guinea pig for now keeping it cheap and simple if i do end up doing it the right way it'll be on something newer and nicer
Old 03-21-2016, 12:46 AM
Vr4junkie's Avatar
So these are new HD tie rods there Synergy Tie rod end used for the Jeep Jk. its a tight fit but they work diffently feels alot better and stronger as you can see.
Now i just need to make a custom Idler arm I have broken 3 already including 2 new ones.
Old 06-08-2016, 07:57 AM
cbr600rx7's Avatar
Looking good. Keep us up to date.
I plan on trying my own 3VZE to OM617 swap using the 4x4labs adapter kit. My only concern is trying to fit that long SOB into the engine bay. Is there enough room in there to push the trans back any?
Old 06-08-2016, 08:18 AM
pyrojoe22's Avatar
There is plenty of room to fit the engine, either by modifying the front core support and leaving the transmission where it is, or leave the front core support alone and moving the transmission back.
Not to step on anyone's toes, but I have V6 kits in stock that can be shipped next-day.
Old 06-25-2016, 10:23 AM
Vr4junkie's Avatar
Well like Projoe22 said there is plenty of room for the engine to fit you might wanna get intouched with him about those motor mounts .
And about the tranny yes there is space to push it back i decided not to because i didn't wanna go thru the trouble of getting new drive shafts and pushing the tranny crossmember back and cutting the oilpan.
Ill see if can post a walk around video of how it is now.
Old 07-03-2016, 04:39 AM
cbr600rx7's Avatar
Those are some good prices pyrojoe22. Do you have a thread on the forums outlining your build or work?
Old 07-03-2016, 06:16 AM
pyrojoe22's Avatar
PM Sent
Quick Reply: 90 V6 OM617 4Runner Swap build
