2.4 Diesel into '91 4Runner ? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Diesel Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-21-2008, 02:52 AM   #1 (permalink)
I have a 1991 runner (rustbucket) with the 3.0 5spd that runs perfectly and a 1990 runner (cherry body) that has a blown 3.0. When the weather warms up I am going to swap the 3.0 into the rustfree runner.
I have this leftover rusty runner that has nothing else wrong with it other than the rust and a saggy rear. Interior perfect, all options work, mechanically great, ect. I have just purchased a 1985 4x4 with a 5 spd and a 2.4 diesel. This truck runs great but the body looks like a dogs a** and the brakes are gone.
I am wondering since the diesel is the same as the 22r as far as bolt locations and such whether I can put that into this old runner with the parts I have. Obviously, I would be using the trans and transfer case from the diesel also. I am not looking for a speed demon, just something to tool around in without scrapping out ol rusty trusty.
Looking for ideas, thanks.
__________________
1990 4runner 4x4 3.0 Auto 205K
1991 Previa All-Trac Auto 161K
1994 Previa All-Trac Auto 198K
1997 Camry XLE 4 cly Auto 173K
2010 Tundra DC 4x4 4.6 Auto 4K
4runnerx2 is offline
Old 02-21-2008, 03:44 AM   #2 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
So, you want to put the 2.4 diesel into the '91 that had the 3.0?
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 02-21-2008, 03:46 AM   #3 (permalink)
Yes, as a way to utilize the 91 body and the diesel driveline.
__________________
Old 02-21-2008, 04:23 AM   #4 (permalink)
thook's Avatar
You can do it. You'll just have to modify for motor mounts and transfer case crossmember.
__________________
Matthew
thook is offline
Old 02-21-2008, 04:27 AM   #5 (permalink)
Could I use the mounts and crossmemeber out of a 22r truck? I have an 87 4x4 with the 22r engine also. Thanks.
__________________
Old 02-21-2008, 05:17 AM   #6 (permalink)
thook's Avatar
The mounting locations on the frame are different, but you can use the parts.....just to have them welded in the right place. For instance, the new mounts will have to sit a bit further back towards the firewall. That's all I know, though.
__________________
Matthew
thook is offline
Old 03-04-2008, 07:33 AM   #7 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
Is your engine a 2L (Normal aspirated) or a 2L-T (Turbo)?
The 2L on a 4Runner must be a dog, the 2L-T it's OK but a bit underpowered...
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write...
Blizzard is offline
Old 03-04-2008, 10:01 PM   #8 (permalink)
David
2L but I am not going to be looking for a speed demon. Just something to put around in. It will be lucky if it ever sees 60 miles per hour
__________________
Old 03-04-2008, 10:06 PM   #9 (permalink)
eightnine's Avatar
FYI the 2L makes only 72 hp @ 4000 RPM with 115 ft·lb @ 2200 RPM. That means its even less powerful than a 22re with 116hp and 140 ft-lb at 2800RPM. Even the 2L-T makes less power than the 22re. Either way good luck with the swap if you plan to go through with it
__________________
1989 Toyota 4runner Special Edition
- Rebuilt 22re bored .20 over 4.30 gears, - Magnaflow Performance Exhaust with Magnaflow Hi Flow Catalytic Converter, Monroe Sensa-Tracs Shocks all around, 4runner AALs, Custom Checkerplate front skid plate, Kayline Soft Top , Clear Corners and Turn Signals, Eagle Alloy Rims with 31x10.5x15 M/T tires, 2 12" JBL Subwoofers / MTX AMP, Pioneer Premiere Speakers, JVC KD-G730 MP3/CD/Bluetooth
eightnine is offline
Old 03-04-2008, 10:37 PM   #10 (permalink)
If it is ungodly slow I might just part both the diesel truck and the 4runner out rather than put my hours in installing the engine. Has anyone ever drove both a 2nd gen 4runner with the 22re and also a 2LT. How do they compare?
__________________
Old 03-15-2008, 06:25 PM   #11 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
I'd NEVER put ANYTHING SMALLER than a 22re in a 2nd gen 4Runner. They are slow with a 22re, I couldnt immagine a 2lt.
Swap the 87 body on the 85 diesel chassis.
Adam F is offline
Old 03-20-2008, 05:46 PM   #12 (permalink)
mrnick1979's Avatar
if you dont do the swap i would be interested in buying the diesel from you, i have a 92 reg cab 2wd that i want to put a 2l in.
mrnick1979 is offline
Old 05-04-2008, 10:09 AM   #13 (permalink)
Do it. Build something solid and it will run forever. the 2L's last forever and if you don't plan on going 60+ then there should be no hesitation. expect 30MPG
__________________
Project Nutkase - Hybrid 1st/2nd gen Hilux, ground up rebuild
1987 Toyota Pickup, Carbed 2wd dd 2,000 miles in
Erick is offline
Old 12-29-2008, 03:04 PM   #14 (permalink)
Was the swap done?
EstebanC is offline
Tags
22re, 24, 2lt, 30, 4runner, 90, 91, diesel, disel, engine, good, motor, put, runner, swap, toyota, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
more diesel talk, how 'bout diesel fuel additives?! hiluxsurf General Vehicle Related Topics (Non Year Related) 6 11-30-2007 10:55 AM
'85 Diesel 4Runner ocdropzone 84-85 Trucks & 4Runners 21 06-24-2007 08:10 PM
Turbo Diesel in a 4Runner? DeckerT4R 95.5-2004 Tacomas & 96-2002 4Runners 18 09-30-2006 11:00 AM
diesel in 85, 0r 86-89 4runner? cd4runner 95.5-2004 Tacomas & 96-2002 4Runners 1 05-05-2005 06:52 PM
4runner diesel??? Oakboy 95.5-2004 Tacomas & 96-2002 4Runners 28 02-07-2004 09:48 AM
2009 InternetBrands, Inc.
