Jeep AW4 TCU to control a340h in 1UZ swap(x-jeepters chime in!) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > All Other Toyota Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-14-2008, 02:42 PM   #1 (permalink)
cheap4r's Avatar
I have been doing a lot of searching on this and was wondering if you old xj jeepsters could help me out
This is what i know (or think i know)
The Jeep AW4 is made by Asian Warner and is remarkably similar to the A340F
internals and solenoids similar a340H (tcases aside)
The Jeep AW4 uses a transmission control Unit (TCU) to regulate all solenoids.
The solenoids are very similar (possibly interchangeable with a340x's)
here is the question...
I am about 2 weeks away from putting a 1UZ in my 1994 4runner, can I wire an AW4 TCU to control my transmission (a340h) instead of having the 1UZ ecu try and interpret/send the incompatible signals? This is a wiring diagram for an AW4 with Economy/Power switch similar to our transmissions.
http://www.greatlakesxj.com/tech/TCU4.jpg
AW4 TCU inputs:
TPS
Brake switch
economy/power switch
12 v (switched)
speed sensor
I’ve seen Lextreame.com uzswap.com but never heard anyone speak of this option. Am I just thinking about this wrong? Thanks!
__________________
Projects:
[DONE] 1993 4Runner: Seized Crank, 200k, NO RUST! Bought for $300
1998 Moto Guzzi California In a few parts... but they are mostly the parts that count...
Toys:
1990 Thunderbird SC: Supercharged 3.8L, 373 rear, 14 piece Widebody kit, 315/35/ZR17 (rear) 285/40/ZR17 (front) w/ Billet Specialties Customs
cheap4r is offline
Old 08-17-2008, 09:08 AM   #2 (permalink)
76ANTHONY's Avatar
very interesting question. i'll be watching for an answer
76ANTHONY is offline
Old 09-14-2008, 07:34 AM   #3 (permalink)
R.DesJardin's Avatar
Ecu
Well if I'm not mistaken you have left out the fact the the ECT is connected to the ECU. The info I found is that ECT takes signals from the ECU to tell when to shift the transmission. There are only a few wires that actually are connected to it, basically two speed sensors, a pressure sensor, gear lever position and solenoids? Iwould also like to know if the signal are different, seems unlikely but who know.
__________________
R.DesJardin-
Automatic to manual in less than a second.
http://www.radesignsproducts.com
"I shift because I can!"
R.DesJardin is offline
Old 09-14-2008, 08:21 AM   #4 (permalink)
CJM
CJM's Avatar
I cant recall the website, but a guy made a manual shift control box for both the jeep and the yota transmissions. Its 100% pushbutton or joystick setup and works very well afaik.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 12-05-2008, 11:10 AM   #5 (permalink)
meswoleshane's Avatar
Yes they are.
meswoleshane is offline
Tags
asian, aw4, crankshaft, guzzi, jeep, manual, modifications, moto, pressure, sensor, shift, solenoid, swap, transmission, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1uz in my jeep 80cj3b All Other Toyota Swaps 25 09-16-2009 05:19 AM
1uz swap!!! rdd014runner All Other Toyota Swaps 17 12-09-2008 02:13 PM
1uZ Swap Donor - Lexus SC400 $1500 GrillmasterP The Classifieds GraveYard 0 02-27-2008 08:53 AM
1UZ-FE or not to 1UZ-FE, that is the question. 1989toy4wd 86-95 Trucks & 4Runners 15 09-27-2007 10:47 AM
A340H modification for 3.4 SWAP FireMan 86-95 Trucks & 4Runners 5 01-13-2006 06:21 PM
2009 InternetBrands, Inc.
