Swap issues- intake leak/idle issue
Old 12-31-2009, 06:30 AM
TatonkaII's Avatar
Sorry to post a new thread and not doing a build up here to keep it all together...
So after doing my swap and got her cranked up I've hit a few snags.
First, I have an exhaust leak from the exhaust manifold and haven't installed a full exhaust system behind my 1st 02 sensor (which is plugged in). I have codes popping up but don't have a scanner yet.
My main concerns are the following:
1.) I thought I had a vacuum leak, but it seems that its leaking from my stock intake manifold at the very bottom where it bolts to the engine. The leak is creating a very high pitched squealing sound. Is this a common thing for 3.4s?? (A manifold leak at 70K miles.) Seems like an easy task, but a hassle.
I searched and came up with this p/n for the gasket: can anyone confirm?
17176-62040
2.) I seem to have my timing off just barely, when its cold I can hear a soft knock every 15-30sec if that, it doesn't even do it all the time. However, because my exhaust system isn't on and there is no real back pressure, couldn't that be the cause?
3.) My idle fluctuates when the engine is cold. When I first start it its really high then suddenly drops and almost stalls, then gets high and almost stalls. It does that a couple times and levels out to a low idle. I assume this is because I don't have an exhaust system and have the gasket leak...
4.) At idle/playing with the throttle some, how long would you say it would take for the thermostat to open? I ran mine till the temp gauge got stable (a little under half) and it didn't opened up.
Anyway, otherwise the engine sounds great.
Thanks guys..
Chuck
Old 12-31-2009, 02:00 PM
TatonkaII's Avatar
here is a vid i took week ago, you can kinda hear it in this...
http://www.youtube.com/watch?v=IqrlKQgVnpw
Old 12-31-2009, 03:30 PM
RobD's Avatar
I can only give insight into question 3. Mine did something similar a little bit after I got my swap done, where it would surge, almost die, surge, almost die, and so on. Turned out I had a vacuum leak in one of the hoses. Not sure if that's what's happening to you, or it could be related to the intake gasket leak you found.
Old 01-03-2010, 08:46 AM
TatonkaII's Avatar
Anyone else have any input?
I've check the codes today and look over for any other vacuum leaks.
Thanks,
Chuck
Old 01-03-2010, 02:21 PM
TatonkaII's Avatar
i pulled the codes.. only had one: P-0717
This was done with the truck on "on" position and at idle running for ~10 mins.
Old 01-08-2010, 03:00 PM
TatonkaII's Avatar
Originally Posted by TatonkaII
17176-62040
If anyone cares that is the correct part number for the plenium (sp) gasket. I've got some time tomorrow so I hope get fix my intake leak them. On sunday I hope to get my exhaust mocked up.. anyway I hope everyone has a great weekend!
Old 01-09-2010, 05:40 PM
TatonkaII's Avatar
Sooo.. my intake/plenum (sp) is cracked on the bottom. Anyone have one lying around after a S/C install?
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
coryc85
09-09-2015 06:24 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Swap issues- intake leak/idle issue
