| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#51 (permalink) | |||||
#52 (permalink) |
on the way to drop rob off, he reminded me athat we didn't hook up the body ground yet, we just stufed the battery in to fire it up, tomorrow, we will hook up the body grounds and build a battery tray when I get off work, hopefully that takes care of that.
#53 (permalink) |
Also got the exhaust buttoned up.
had to move the front o2 sensor over, it was hitting the frame ![]() just attached the factory t100 downpipe to the exhaust that was already under the truck ![]() The factory o2 bung for the 3.0 is now where the rear o2 will reside, but it is gonna have the bypass box, it will stay there for the heater though. ![]() one more shot
#54 (permalink) |
Got the battery tray made, wound up haveing a plugged injector, that is what was setting the p1300 ignitor code, good thing we had 6 spares off the junk 3.4. Still has a high idle, gonna go hook up the rear o2 heater and it still needs an air filter and the wiring finished up. we are gonna go chop up the hood so we can put it back on too.
#55 (permalink) |
Idles still way high, and I hooked up the rear o2 sensor bypass that elvota did, and now it is setting the p1300 again.
Elvota, which wire colors did you hook up to? and which were the heater wires? Also, got the tach fixed, the wire in the dash harness changed color somewhere, so once I ohmed the right wire and hooked it up, the tach now works.
#56 (permalink) | |
Quote:
This is for the NGK/NTK O2 sensors that I used in mine. Hope they help: http://www.ngksparkplugs.com/images/...t_11-16-04.pdf
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio Last edited by RobD; 02-02-2008 at 10:10 PM. |
#57 (permalink) | |
Quote:
I don't see why a bad secondary O2 would effect idle. That O2 only checks the cats performance. If below par, it pops up a code. You could try unplugging to O2 completely and see if that changes anything. My bet is it wont.... besides generating another code. My 3.4 idles pretty high until it warms up... that's not what you are experiencing, correct?
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#58 (permalink) |
I think I spliced it in wrong, the rear o2 sensor is the only one that didn't have a plug, somehow it got cut off. it idles that high even when it warms up. I went and drove it around the block, and it was at operating temp, and was still high.
#59 (permalink) |
Hey Elvota, where did you get your air filter and adapters? Rayl82 needs one.
Battery Tray ![]() My Chit ![]() The hole in the hood was alot smaller than I expected ![]() ![]() ![]() just because
#60 (permalink) | |
Quote:
https://www.amsoil.com/storefront/Se...Words=EAAU3051 Part number EAAU3051 in case link doesn't work. I liked the Amsoil product as there is no oil to mess up the MAF. Plus it's got chrome ends. Take a look at this engine pic for reference: ![]() I got a blue "silicone" type adapter from AutoZone and then a small section of the ricer chrome intake tube. On the intake side of the MAF there was a small ridge designed to hold on to the factory intake. I simply ground off most of this ridge, and then attached the blue coupler/ chrome pipe/ air filter in that order. I brought the filter and MAF into AutoZone to see what I needed. I also built a bracket to support the assembly and mounted that from the inner fender to the two holes under the MAF. The rest of the intake is all OEM. Seems to work well... at least I haven't had any issues yet. Nice that you were able to keep the hood hole so small. I have enlarged mine slightly. You'll see when you start driving it (especially on the trails) that the motor moves quite a bit and my intake started to rub. Just keep an eye on it and enlarge if necessary. ![]() About your code and high idle... Do you have a way to get a laptop watching your OBD port? I got a pretty cheap interface here: http://www.scantool.net/products/pro...products_id=12 It's only $35 if you don't get the box. Comes with free software but more can be downloaded. They are made right here in Phoenix, AZ... so maybe you could pick one up or shipping is one day. Would give you more info on your code/ idle issue with all sorts of real time monitor data. One reason this interface is so cheap is that it doesn't read all Toyota OBD platforms... so make sure you get the specific one for your year motor. If mine is compatible with your year 3.4, you are welcome to drive over and we can check it out. Or maybe I can come by there if that makes more sense. Just let me know.
__________________
#61 (permalink) |
well, I'm going to Tucson today, and won't be back until tomorrow night, so I can finally take a break from this.
#62 (permalink) |
no truck all weekend wife wont like that
__________________
89 runner on an 85 runner frame and front axle 3.5" lift suspension 31" A/T tires 1.5"wheel spacers on the front ez locker in the rear crossover high steer and oh ya 3.4L v6 85 Runner buggy in the works... |
#63 (permalink) |
Took it to work today, ran good down the freeway, except the engine light on with the p1300, and the 1800 rpm @ idle. Didn't see anything out of the ordinary at work, ran out of time and came home.
Tested the ignitor again, everything tested good, I thought maybe that was the cause of the high idle. So I went back to the high idle, since we had another 3.4, I took the idle control valve off the 1st throttle body and switched them. ![]() Fired it up and it was actually idleing @ 900rpm. Then the p1300 didn't set again yet, I think it was freaking out the ecm because of how high the idle was, it didn't know what to do. So rayl82 is out on a test drive, and I still have some wiring to button up, and I need to lengthen the wires on the trans switches so they reach the plugs, and I need to find the wires for the evap componetnts, but he will probably be able to drive it home tonight, and I will finish up the small things in a few days. We'll see...... |
#64 (permalink) |
wow, yall are awesome
__________________
-Brandon 1988 4Runner SR5 4x4 V6 5 Speed Swap (R150F)~SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5 Pro Comp M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~Marlin Crawler Rear~Addicted Offroad Front Bumper~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss. My 4Runner and Other Stuff |
#65 (permalink) |
So i failed emissions today
forgot to put the cat in the system and had a missing charcoal line it has been plugged previous years but with all the other 3.slo vacuum lines removed they noticed it... guess I'll have to rout that to somewere they cant see. on another note my truck is now a 97' according to emissions right? they should just plug into the obd2 connector and be done with it right? I told the guy when he asked what year it was "its a 97' engine in an 89' 4runner on an 85' 4runner frame." i thing he thought i was joking well I've got 60 days to re-test.
__________________
#66 (permalink) |
As I understand it here, the ECU is what determines the year. But maybe state laws vary on that.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#67 (permalink) |
the engine light has returned,
i had auto zone reset it but the codes set werep0171 p0136 p0136 set twice? p0450 the last one p0450 is the evap code, i cant find the evap plug to connect it the p0171 is the igniter isn't it? and it may be set because of the other codes. does anyone know were the evap plugs are on a 97' Tacoma? jason4x4 is sick with the flu so i don't want to bother him...
__________________
#68 (permalink) |
http://www.tacomaterritory.com/wiki/..._Trouble_Codes
P0136 02 Sensor Circuit Bank 1 Sensor 2 (that's the rear O2 sensor) P0171 System Too Lean Bank 1 P0450 Evaporative Emission System Pressure Sensor/Switch Not sure what you mean by "evap plugs"?
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 02-10-2008 at 12:10 PM. |
#69 (permalink) |
Hope these help.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#70 (permalink) |
On a side note, I never did put my evap canister in. Is this critical to the operation of the engine, or is it more to pass the emission laws for your locale? Are there any up- or downsides to not using it?
__________________
#71 (permalink) | |
Quote:
the plug that the ecu watches, otherwise how does the ecu know it's not there?
__________________
#72 (permalink) |
thanks robb, the rear o2 is bypassed like elvota's but my cat has a "Black eye" beacuse when it got pluged up i punched it... so that's throwing the o2 code and the evap is not in the system i don't know were to hook it in at. i think between the two problems the ecu is leaning me out i'll get it eventualy thanks for the help...
__________________
#73 (permalink) | |
Quote:
__________________
#74 (permalink) |
i think the evap stuff has a switch that the ecu reads and thats why my engine light is on but i could be wrong...
__________________
#75 (permalink) | |
Quote:
__________________
| Tags |
| 34, control, emission, error, evaporative, fsm, malfunction, po450, pressure, sensor, solder, switching, system, tach, tacoma, toyota, valve, vsv |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| CV Swap ?'s | matthewdmueller | 86-95 Trucks & 4Runners | 3 | 10-26-2007 09:05 AM |
| 1991 4Runner body swap or engine/tranny swap? | 91slowrunner | 86-95 Trucks & 4Runners | 2 | 05-21-2007 10:11 PM |
| 4.3 V8 Swap | 1styota4X4 | 86-95 Trucks & 4Runners | 8 | 07-28-2006 07:35 AM |
| Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? | Justin311 | 86-95 Trucks & 4Runners | 15 | 04-15-2006 12:18 AM |
| 4wd problem/tranny swap/t-case swap wtf | squishy321 | Offroad Tech | 2 | 04-01-2005 11:41 AM |
