My 3.4 swap is starting back up!
I have been away for awhile and now I am coming back to it. Fishing season is just about done and my elk hunt is over now. So it is back to the shop to finish this beast. installing new heads on the motor this weekend, all of the lower end has been rebuilt and bored over. Today I am sitting down with the wiring harness and swapping connectors, AT wire harness to MT ECU. thanks to theMonch this should not be too bad. wish me luck.
Ok may be going a different route now....but still a swap of sorts. Just found a t100 with a ton of miles on it. So I am thinking of getting it and putting my freshly rebuilt 3.4 in it. Now I have to get rid of a lot of swap parts. I have 2 wire harnesses, two 3.4 M/T ecu, ceramic coated crossover built by toyotaonlyswsps and a few other parts I don't need. I think the t100 would be an easier route and better for what I do, hunting and fishing.
The only problem is that the 97 sr5 4x4 M/T t100 has 310k but still runs great. I want to swap engine right away but I have read that some of these engine just run forever if properly maintained.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
09-22-2015 07:25 PM
