Lysmachia's CAB/Engine Swap for Tippy
#83
Oh so it looks like I need a T100 (2WD) Oil Sump to fit the pan I got from ORS. I have called so many auto salvage places and while I did find on extra pan (for MrDoug) there were no sumps.
Grrr...
Any ideas on where I might find one used? Or did any of you do a conversion yourself on the 3.4 sump on your donor engine?
Grrr...
#84
So, if your current 3.0 setup worked... just swap it all over to your 3.4.
#86
I am so confused. I got the T100 pan, but now I have to move the sump for it to fit. I didn't think I was going to have to.
What is the difference between the 3.4 pan and the 3.0? I assume they have the bumnp on the same side since the sump has to fit in either pan. Is one shallower than the other?
#90
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I know I can't help with any of the tech to help you Molly, just wanted to wish you good luck with the swap, and glad to see that your working on poor Tippy!!!!
#91
IIRC the main difference was the 3.0 was made to fit around a diff on the passinger side and the 3.4 had the diff on the drivers side. So they were scooped out to fit around the diffs on different sides.
#92
I wonder why they flipped the driveline around when they switched to the 3.4? Anybody know?
#93
Well I went ahead and pulled the sump and then put the T100 pan on - so I can see how it will fit when we drop the engine in.
Then we did the timing belt:
White hot timing belt action...
Thank god we had MrDoug's nifty pully tool!
What a bitch getting that belt on!
I got fired. Nate took my place.
Moving Tippy to put the engine in:
Nate cleaning out the bell housing.
I'm wiping up the mess
What a dork!
Shortly after this we decided the engine wasn't going in till I do the cross-over exhaust. Then we got a call for a rescue of a TJ7 up on left hand, so we went for a very wet, rainy, and extremely slick and muddy rescue...
What a dork!
#94
Ya know Molly those engine stands usually have a "spin" feature to make it easy to work on the bottom end from a standing position...
What a dork!
Cute pic... for some reason a butt in the air always makes me think of paddy whacks...
What a dork!
#97
So yesterday for my Birthday Troy surprised me this donor "Top" that we are gonna swap onto Tippy's frame. Probably gonna go with the 5VZFE (3.4) Donor motor I already have instead of rebuilding the 22RE. Will probably do a dash swap if we can swing it, to avoid the wiring harness. Don't get your hopes up to see the "new" Tippy any time soon. Cash is at a minimum and lots to be done (though Troy has connections and he got the body for a song I hope).
Any way it was an awesome surprise and I promptly seized later that night to show my appreciation. (Go figure)
Is it weird I am more worried about the crossover pipe than I am the wiring?
#98
Not weird at all! Use the stock crossover, modify it to exit left. Beware the bellhousing & firewall clearance. Also make sure the end is higher than stock & you will have fewer worries with frame rail clearance. Ceramic coat it & you is joyful!!
