JDM Oil Pan?
Old 08-06-2015, 09:47 AM
falcon4runner's Avatar
JDM Oil Pan?
Hi everyone,
I've been working on swapping a 3.4l into a 1995 4runner that I am also SASing. I have worked on a number of these motors, including replacing blown motors with JDM low mileage engines.
Needless to say, I have amassed a number of extra parts from them. These Japanese domestic market motors have an oil pan that I have not seen before and cannot for the life of me identify what they came from (I have searched high and low). They seem like they would be very good candidates for low solid axle swaps and look very close to 2wd T100 pans.
What are your thoughts on this? Does anyone know what these pans are from?
Thanks for your input. Here are the pics. It is a rear sump pan (the pickup tube is facing the wrong way).
Old 08-06-2015, 10:35 AM
RBX
RBX's Avatar
Either the driver side drop of the diff which started in 95' or the engines are out of the HiAce vans
Old 08-06-2015, 10:52 AM
That would make a lot of sense. The HiAce was the only thing that I could think of really that had 3.4l.
Old 08-06-2015, 11:08 AM
Ok, I found the part number for that pan. 12101-62090 for the Gravia/Grand HiAce. I am going to look into using it, but I don't see that it would be something beneficial unless you had one laying around.
Thanks for the help.
Old 08-06-2015, 01:44 PM
RBX
RBX's Avatar
3vz oil pans fit the 5vz also
Old 08-06-2015, 01:58 PM
Yeah, the 3vz pan was what I was going to use (and most likely still use), but I am also doing a lower SAS on the truck. I have heard that I may have oil pan interference with the 3vz pan. Still need to mock it up, so I don't know if I will have problems in my case. I will post up once I have it figured out.
Old 08-06-2015, 02:36 PM
RBX
RBX's Avatar
2wd pan is slimmer in the front
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
irritech
07-27-2015 05:15 PM
toofly1999
07-25-2015 07:09 PM
tobylab
07-12-2015 12:53 PM
Quick Reply: JDM Oil Pan?
