irab88 adds another liter: 22R-EC to 5VZ-FE
Old 02-04-2015, 07:56 AM
  #201
irab88's Avatar
cool. i'm inviting a few peeps down, i'll see how many we get.
Old 02-07-2015, 02:31 PM
  #202
irab88's Avatar
today's progress: finished up the timing belt and radiator. still need a lower radiator hose (picking it up later this week)
looks like i've had it there all along!
and no loss of blood! yay!
Old 02-10-2015, 10:47 AM
  #203
irab88's Avatar
i looks so weird... like, almost stock, but not quite right. like it's not my truck. (but i know it is, i've put my blood and sweat into it)
i picked up the rad hose yesterday, but the weather has been less than crappy.
for the electrical, i'll be moving the battery to the bed and making a new bus bar setup up front. i already scored some cheap 2/0 cable, and can re-use the old bars in a different configuration. something that's easier to work on, and looks more professional
Old 02-11-2015, 08:47 AM
  #204
RBX
RBX's Avatar
Little bit at a time. weather seriously sucks this year.
Old 02-11-2015, 11:18 AM
  #205
rattlewagon's Avatar
Whats the matter, you guys arnt used to the cold?
Old 02-11-2015, 11:59 AM
  #206
irab88's Avatar
being used to something doesn't mean i have to like it. i'm used to paying taxes. i'm used to bad traffic. i'm used to not having a nice, clean, well-lit, open garage:
temporary_zps2f9aa7d6.jpg?t=1419133274
Old 02-11-2015, 12:15 PM
  #207
RBX
RBX's Avatar
^^^ yeah really easy to talk about not likeing the cold when you have a nice garage.
I'm with Ian on this one!
Old 04-06-2015, 06:02 PM
  #208
irab88's Avatar
this past weekend i sold the boat, so that's more money into the motorhome-bus fund
also worked on the celica a bit. new led dome lights... oooh!
aaaand as for the engine swap: i tried putting the lower radiator hose on, but it was about two inches off... two inches... just like the two-inch body lift i put on... oh. 5 minutes later, the radiator brackets put the radiator where it should be. both upper and lower radiator hoses are installed.
the water lines, trans, electronics, belts, vacuum, and most of the intake are all done. driveshafts, crossmember, interior, and power wiring are still left. time to get on it!
Old 04-14-2015, 08:45 AM
  #209
jon.r's Avatar
Looking good man, I am in the midst of doing this swap (3.0 to 3.4) and found your timeline and milestones fairly motivating. I am delving into the wiring this weekend...
Old 04-14-2015, 10:18 AM
  #210
irab88's Avatar
the 3.0-3.4 swap will be much easier for you. the wiring isn't too complex until you get to the dash. since i'm not worrying about it, i really only have the battery wiring to hook up yet.
good luck on your swap!
Old 05-01-2015, 08:00 AM
  #211
irab88's Avatar
this weekend i'll be working on the truck, hopefully a bunch. i have a welder, scrap steel, good weather, a few parts, and only one interruption (a movie).
left to do:
- exhaust
- driveshafts
- electric (battery, starter, alt, etc)
- dash
- interior
- shifters
also, i picked up a free gen-1 kindle with a bad screen. i'm going to replace the screen ($10 part) and see about using that as my dash, after i install android os.
Old 05-01-2015, 08:25 AM
  #212
jon.r's Avatar
left to do:
- exhaust
- driveshafts
- dash
- interior
- shifters
Love it. I am doing a Nexus 7 install in mine. As I go through my build, I think back to you and your thread and think: "Well, at least I am making more progress than jrab88"
Haha, just kidding man, I should put up a build thread of my own to show my non-progress.
Old 05-01-2015, 08:51 AM
  #213
irab88's Avatar
yeah, start a thread! it's fun, if only to provide your own motivation.
and i already know there are people who are a LOT quicker than i am. i just have other life events and non-toyota hobbies that take some of my attention.
Old 05-01-2015, 02:16 PM
  #214
Good points! Haha!
I like the kindle in the dash idea!
Old 05-04-2015, 06:16 AM
  #215
irab88's Avatar
using the kindle specifically wasn't my initial idea. since i got it for dirt cheap, i'll try using it. if it doesn't work, i'll splurge on a cheap android tablet (original plan). the new screen comes tonight, so i'll try some stuff out.
also, i realized that the kindle doesn't have bluetooth. i might just get the android table instead, because the wifi obd-2 scanner is more than a tablet. hmm...
Old 05-04-2015, 07:43 AM
  #216
jon.r's Avatar
For what it's worth, the Nexus 7 (2013) has a plethora of support for a dash install. There are a few forums out there that supply specialized kernels and mods that will allow it to charge from power and allow for usb hubs to attach.
Of course these are all just words until I show it installed. Until then, check out this clean install with many bells and whistles to perk your interest:
Oh, and the Nexus 7 2013 fits perfectly in a double din enclosure.
Old 05-19-2015, 04:41 AM
  #217
RBX
RBX's Avatar
Ian,
What software are you using to monitor the engine diagnostics? What can the software do? I'm looking at getting the Techstream and dongle for my install.
Old 05-19-2015, 06:34 AM
  #218
irab88's Avatar
i bought an android tablet (less than $50) on ebay. since i'm only using it as a dashboard, the only real software i'll be using is torque (i went ahead and paid $5 for pro) along with a few other diagnostic programs.
i have a obdlink bluetooth scanner, which is a heckuva lot faster than the $4 "elm327" -type scanners. the software for the scanner (published by obdlink) is pretty nice, as it shows all pid's, trouble codes, and allows for code-reset.
Old 05-19-2015, 06:46 AM
  #219
RBX
RBX's Avatar
Good to know.
I've read that the Torque app is just for monitoring, which is why I downloaded the Techstream software. Ordering a 25$ MVCI OBD2 cable from amazon so I can talk to the ECU and reflash if necessary. The 2010 Hilux has updated immobilizer and injector diagnostics. If I need to replace sensors or injectors the ECU needs to be prompted to register the new injectors for calibration, otherwise...no worky.
thanks
Old 06-19-2015, 05:33 PM
  #220
RBX
RBX's Avatar
You need techstream and the $28 obd2 USB cable from Amazon. Now get to work and update this thread.
Quick Reply: irab88 adds another liter: 22R-EC to 5VZ-FE
