| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Ignitor test?
#2 (permalink) |
make sure the bracket for the ignitor has a good ground.
__________________
Concrete is the cancer of our land,just give me rocks and dirt.............. |
#3 (permalink) |
Yes you can check. Find which pins go to the coils, find the one that goes to the rev counter, find the 12v. Find the one that sends the signal from the ecu to fire a coil. The remaining one should be the "fired" or "signal good" pin. It sends out a confirmation pulse to the ecu every time a spark signal is sent to a coil. If you have a scope you can look at the pulse train on that pin. If its not there or is skipping pulses, the ignitor or coils are bad. If all pulses are there and its not sparking or has a weak spark, coils, wires or plugs are bad.
You can also scope the individual wire to the coils. You could also have a bad connection from the ecu to the ignitor. Could be your ecu if the connection between it and the ignitor is good and pulses are missing from the ecu. If you have the fsm a full test procedure is in there but you do need an oscilloscope to test it. Or you could connect a transistor to the wire under test and have it light an LED every time a pulse is present. If you want to do it with an LED let me know and I will draw you a schematic. Last edited by UKrunner; 12-02-2009 at 11:40 AM. |
#4 (permalink) |
Thanks i will have to check out the FSM again. I found the sheet that tells you how to check the coils and other sensors but all it said for the ignitor and ECM was try another one.
If you dont mind Id like to see how you test it with an LED |
| Tags |
| ignitor, test |
