Conversion Wiring
#63
what sensors need to be changed on the engines side of things? I know the 3.4 runs a map, and other things. will this harness work for California type trucks wanting to be bar'd by the ref?
Also i take it we will have to use a specf year ecu for the harness correct.
#65
No sensor changes, use the ones that came with the donor engine. You will need a Cal spec ecu if you want to pass ref. I will need to know the ecu part #.
olharleyman pm'ed you.
#69
tmz, goog luck on your website!!
Do you know of any good sources for 5vz's. Toyota are few and far between in my area it seems. Also the local junkyards dont want to work with someone like myself, who cannot generate a list of all the parts i need. it would also be helpful to take the donar apart myself so i can see how it all goes together, rather than have someone just rip my apart.
#70
am still working on pricing. I do not need your harness to do this unless your ECU does not match your harness and you need it repinned. I am working on a stand alone harness that can be used in a buggy or race truck. I will also be doing harnesses for 2rz, 3rz, and Lexus V8. Complete E-Locker harness from switch to locker will be available soon
3.4 Conversion Harness $350.
Convert Auto to Manual + $50.
Repin Harness + $100 I will supply the needed connectors
URD Rear O2 sim + $100 I will supply the sim
#79
its for a house phone, duh. im not really into having a cell phone.
just playing, i have no idea what it is, but it probably is important if Tim has it wired in there.
jason
jason
