aussie 3.4 swap
G'day
Below are the wires as they are in each plug.
Standard plugs configuration
IG2 Dark Grey 4runner body
operation color
transfer indication switch white/black
purple/white
check engine warning light purple
o/d main switch to ecu yellow/green
stop light switch to ecu green/white
fuel pump blue
to ac amplifier blue/black
cruise to check connector yellow/black
battery feed to ecu black/green
grey/blue
ignition feed to engine components black/red
starter feed to inhibitor switch black
positive from efi relay white/red
water temp switch for ac blue
speed sensor to combination meter green/blue
from starter motor black/white
circuit opening relay to airflow meter green/yellow
cruise control yellow/red
IG3 white plug 4runner body
Operation Color
transfer fluid temp sensor green/white
ect pattern select red/blue
cruise control red/white
to vsv for idle up for ac blue
from ac amp to ecu black/red
reverse signal red/black
ADD detection switch green/yellow
oil pressure switch yellow/blue
brown
inhibitor ignition feed black/orange
engine temp sensor yellow/green
ac magnetic clutch feed black/white
A/T oil temp feed to combination blue/white
tacho feed black
IJ1 5vz
Operation Color
earth white/black
power feed to inhibitor switch and ect red/blue
injector feed black/red
fuel pump red/black
to tacho blue
water temp sensor yellow
earth brown
oil pressure yellow/green
4wd detection switch black
from speed sensor in combination blue/red
earth brown
abs to check connector white/blue
abs pink/blue
abs blue/black
abs white
abs red/green
immobiliser green
evap cannister pink
magnetic clutch switch black/yellow
l4 detection switch light green
green/white
cranking feed to ecu red
check connector te2 blue/red
check engine warning light yellow/red
from efi relay black
IJ2 5vz
Operation Color
inhibitor 2nd gear green/white
inhibitor neutral green/red
inhibitor 1st gear green/black
2nd start yellow/green
ect pattern yellow
crank feed to inhibitor black/white
return from inhibitor black
blue
red/yellow
ignition feed to inhibitor green
4wd transfer solinoid return green/orange
Plug D 5vz
Operation Color
A/T oil temp switch yellow/black
from ac amplifier blue/black
overdrive switch purple/green
to cruise purple/red
sub fuel switch green/yellow
sub fuel gauge pink
ect power select green/yellow
from speedo purple/white
battery constant black/yellow
sub fuel orange
to detection switch transfer neutral blue
immobiliser pink/green
immobiliser brown/red
to ac amplifier blue/yellow
green/yellow
circuit opening relay ground red/white
from stop light switch green/white
sub fuel pump red/green
fuel pump red/black
operation color
purple/white
fuel pump blue
grey/blue
Operation Color
brown
tacho feed black
IJ1 5vz
Operation Color
earth white/black
fuel pump red/black
to tacho blue
earth brown
earth brown
abs pink/blue
abs blue/black
abs white
abs red/green
immobiliser green
evap cannister pink
green/white
IJ2 5vz
Operation Color
ect pattern yellow
blue
red/yellow
Plug D 5vz
Operation Color
sub fuel gauge pink
sub fuel orange
green/yellow
fuel pump red/black
G'day
And this is how ive got them connected up, please take the time to have a bit of a look.
IG2 Dark Grey
Pin Color Connection
1 White/black IJ1 PIN 4
3 purple IJ1 PIN 22
4 yellow/green Plug D pin 6
5 green/white Plug D pin 25
6 Blue Plug D pin 28 IJ1 pin 12
7 blue/black Plug D pin 20
10 black/green Plug D pin 14
14 Black/red IJ1 pin 1
15 black
16 white/red Plug D pin 22 IJ1 pin 13
20 green/blue IJ1 pin 6
22 black/white
23 green/yellow Plug D pin 24
IG3 white plug
1 green/white IJ1 pin 23
2 red/blue Plug D pin 10
6 black/red Plug D pin 5
7 red/black IJ1 pin 23
10 green/yellow
11 yellow/blue IJ1 pin 8
16 black/orange IJ2 pin 7
18 yellow/green IJ1 pin 10
19 black/white IJ1 pin 21
20 blue/white Plug D pin 4
24 black IJ1 pin 11
IJ1 5vz
4 white/black IJ1 pin 9
2 red/black IG3 pin 7
1 black/red IG2 pin 14
12 red/black Plug D pin 28 IG2 pin 6
11 blue IG3 pin 24
10 yellow IG3 pin 18
9 brown IJ1 pin 4
8 yellow/green IG3 pin 11
7 black Plug D pin 26 and pink/green of front diff
6 blue/red IG2 pin 20
20 brown IJ1 pin 4 and 9
21 black/yellow IG3 pin 19
26 light green
24 red
23 blue/red Plug D pin 11
22 yellow/red IG2 pin 3
13 black Plug D pin 22 IG2 pin 16
IJ2 5vz
3 green/black Plug D pin 3
11 black/white
10 black
7 green IG3 pin 16
6 green/orange
9 blue
Plug D 5vz
2 green/white IJ2 pin 5
3 green/black IJ2 pin 3
4 yellow/black IG3 pin 20
5 blue/black IG3 pin 6
6 purple/green IG2 pin 4
10 green/yellow IG3 pin 2
11 blue/red IJ1 23
12 purple/white
14 black/yellow IG2 10
20 black/yellow IG2 pin 7
22 black IJ1 13 IG2 pin 16
24 red/white IG2 23
25 green/white IG2 pin 5
26 black IJ1 pin 7 and pink/green from front diff
28 red/black IG2 pin 6
Cheers
IG2 Dark Grey
3 purple IJ1 PIN 22
15 black
22 black/white
IG3 white plug
10 green/yellow
24 black IJ1 pin 11
IJ1 5vz
11 blue IG3 pin 24
9 brown IJ1 pin 4
26 light green
24 red
IJ2 5vz
11 black/white
10 black
7 green IG3 pin 16
6 green/orange
9 blue
Plug D 5vz
11 blue/red IJ1 23
12 purple/white
24 red/white IG2 23
Cheers
G'day
Today i checked out the output of the ignitor to the ecu, it shows 5 volts from the time the key is turned, when it starts, then dies and untill you turn the key off. So from what ive read that means its working as it should.
I repinned the ignitor and maf again to no avail.
What else can i check over???
Ive done a search and all the stuff i find seams to relate to the maf but ive checked mine against all the problems and it seams to be fine.
Cheers
Cheers
Flying91
45
04-11-2024 04:39 PM
LosPatosDelSur
23
03-12-2021 03:08 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
