93 4Runner 3.0 - 3.4 conversion w/ auto - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-13-2004, 12:55 PM   #26 (permalink)
SOUNDS COOL,
I TOO AM PLANNING A CONVERSION ON MY 1990 4-RUNNER.
WOULD YOU MIND ANSWERING SOME QUESTIONS DURING MY TRANSPLANT? I AM A LITTLE NERVOUS ABOUT THE WHOLE THING AND I WANT TO MAKE SURE I DO THIS TRANSPLANT CORRECTLY. I HAVE A 2001 TACOMA ENGINE AND TRANSMISSION WITH A 1981 TRANSFER CASE. WHAT KIND OF LIFT DID YOU DO TO YOUR TRUCK AND WHO MAKES IT FOR THE AUTOMATIC? WHAT DO I NEED TO DO WITH THE TRANSFER CASE TO MAKE I WORK? I AM GOING TO GET THE KIT FROM OFFROAD SOLUTUIONS AS WELL.CAN I USE THE EXISTING SHIFTER OR DO I NEED ALL 2001 SHIFTER AND LINKAGE? WHERE IS A GOOD PLACE TO GET THE WIRE HARNESS AND COMPUTER? THE ENGINE IS FROM A TWO WHEEL DRIVE TRUCK. SO I THINK I NEED A NEW WIRE HARNESS AND COMPUTER? ANYTHING ELSE I MIGHT NEED TO KNOW WOULD BE COOL. THANKS FOR YOUR HELP , PAUL
Yamahar1 is offline
Old 11-19-2004, 06:34 AM   #27 (permalink)
Babypig's Avatar
Quote:
Originally Posted by Scottz
Tach. When I did my 3.0 to 3.4 swap I used a Autometer tach with the stock gauge. I simply removed the stock tach circutboard leaving the needle assembly, then took the Autometer circutboard and wired it to the stock needle ( 3 wires ) then wired the power, ign.,and ground from the three screws on the back of the gluster witch is the same place the factory tach gets it's power. And now I also have a shift lite. It only took about 2 hours to do and I still have the factory look with a little blue led shift lite.
Pics
__________________
Ironpig2 is a 1990 4runner SR5
95 3.0V6, ARB front bumper, Hella H4 conversion, Hayden Trans cooler, Aisin manual hubs, Drilled headlight bezel, Clinometer, Altimiter, Assorted Camera mounts, JVC double din head unit, Hilux Surf emblems, Bridgestone Revo's, OME 901's , N72f's
"Stay calm, Be brave, Wait for the signs."
Babypig is offline
Old 11-19-2004, 08:09 AM   #28 (permalink)
Send a message via AIM to TeamShiftPoint
aLostDawg, any updates on getting the truck started??
__________________
William
teamshiftpoint@ev1.net
-2001 Sequoia SR5 V8 4WD
-2002 Tundra Limited V8 4WD TRD Ext. Cab
-1990 4Runner SR5 4WD Auto w/ '99 TRD Supercharged V6 Swap (5VZFE) (my cousin has one too!!!)
3.4 swaps with trd s/c completed
(wired up ourselves, tach works):
90 4runner 4wd AUTO
90 4runner 4wd AUTO
93 Toyota Truck 4wd 5spd
TeamShiftPoint is offline
Old 11-20-2004, 08:29 AM   #29 (permalink)
NICE JOB DAWG,
I WANT TO DO THE SAME TO MY 1990 4-RUNNER. DID YOU HAVE TO DO ANYTHING TO YOUR DRIVE SHAFTS? CAN U USE THE 1990 SHIFTER AND LINKAGE?DID YOU HAVE TO RELOCATE ANY OF THE TRANSMITION AND TRANSFER CASE MOUNTS? I AM GOING TO GET THE COMPLETE CONVERSION KIT FROM OFF ROAD SOLUTIONS. ANY PROUBLEMS WITH THERE KIT? THANKS PAUL
Last edited by Cebby; 11-20-2004 at 01:10 PM. Reason: How many times do we need to read the same quote?
Yamahar1 is offline
Old 11-20-2004, 12:48 PM   #30 (permalink)
is your caps lock stuck?
__________________
William
90 4runner 4wd AUTO
90 4runner 4wd AUTO
Old 11-20-2004, 09:56 PM   #31 (permalink)
Flygtenstein's Avatar
Yeah Jim, just keep checking fluids. I carry a quart of ATF and a funnel in the truck permanently.
ORS sells the parts and wiring to get it done, but you still need to have an idea of what is going on. It is a kit in so much as it is a compilation of parts, not like a kit car where all the little pieces go together and make a complete model.
Flygtenstein is offline
Old 01-17-2009, 10:20 AM   #32 (permalink)
Hello,
I have the same 93 4runner and have been strongly considering the same engine swap. Ive had the truck for 6 years and Ive had enough with the fact that the 3.0 is way under powered and sucks the hell out of fuel. Im am interested in hearing more on your conversion, when will you be posting more info on it? And just out of curiosity, does the original trans for 3.0 compatable (connection wise) with the 3.4?
Thanks,
merle
rxdrummd is offline
Old 01-17-2009, 10:21 AM   #33 (permalink)
Hello
Hello,
Thanks,
merle
rxdrummd is offline
Old 01-17-2009, 10:50 AM   #34 (permalink)
mt_goat's Avatar
Quote:
Originally Posted by rxdrummd View Post
... And just out of curiosity, does the original trans for 3.0 compatable (connection wise) with the 3.4?
Thanks,
merle
No its really not, the speed sensor is not compatable but some have used it anyway or done some customization (see teamshiftpoint's thread).
That original poster hasn't posted over here in 5 years so I wouldn't hold my breath for an anwser LOL. Here's the 3.4 swap section: http://www.yotatech.com/f160/
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 04-26-2009, 08:16 PM   #35 (permalink)
3.0L to3.4L conversion
Crap on a cracker. I just read the gauntlet you ran to upgrade from a 3.0 to a 3.4L. I think you've convinced me that I shouldn't attempt it.
Hat's off to you for enduring it and succeeding!
Sounds like it's running great.
I've got a 1991 V6 w/automatic, 100k miles, with a main bearing going out. I was thinking of buying and installing a long block (a remanufactured 3.0 or better yet a 3.4)... but mama mia, I sounds too complicated for a weekend garage monkey.
I've been brooding over how to find the best remanufacturer in the region ... and whether to attempt the 3.4 conversion.
Thanks for the insights.
edward frank is offline
Tags
30, 34, 4runner, 93, assemble, automatic, conversion, crawler, engine, instructions, landcruiser, main, member, problem, swap, toyota, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
auto hub conversion killa b Newbie Tech Section 16 12-17-2006 04:47 PM
Has anyone done a 4.0 w/ auto trans conversion? MonsterMaxx 86-95 Trucks & 4Runners 9 10-10-2006 07:39 AM
Auto to Standard conversion help davidsunglee1221 95.5-2004 Tacomas & 96-2002 4Runners 0 03-27-2006 10:38 PM
93 4Runner 2WD to 4WD conversion mpsjr 95.5-2004 Tacomas & 96-2002 4Runners 15 12-16-2004 04:56 PM
Auto to Manual conversion. Duec66 95.5-2004 Tacomas & 96-2002 4Runners 4 10-25-2004 08:14 PM
2009 InternetBrands, Inc.
